3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Cheaper way to Stretch your Piercings
Step 3Shaping & Sizing
Shaping & Sizing
The last step is to actually fabricate the thing. Take your time and take acurate measurements, you'll thank youself later. A set of calipers or a micrometer comes in handy here. Some other tools will be required at this point, a drill, file, and either a pair of vise-grips or an adjustable wrench.
Now, cut a piece of your selected material to your desired finished length + 1/2" to 3/4". < this extra bit will go into the chuck on your drill. Clamp your drill to a workbench/table. You will basicly be using the drill as a mini lathe.
You will use the wrench or vise-grips in conjuntion with the file. Adjust the opening to cut your specified size. Alternately, you can free-hand this operation with just the file (or any other abrasive) and take frequent measurements.
If you're making a taper, obviously you want to start with the larger diameter and then taper to the smaller one.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:aetherial
