The Complete Collabororative knex war guide by Fred the Penguin
Featured
A realistic war guide, by knexers that know what they are doing, for knexers that suck at knex and fail at life.
Step 1: Tactics
Ok, tactics.
Well first of all it depends on your gun, what works for a Tr18 probably won't work for a Wrectangle, but here's a few general tactics, we'll get to more specialized tactics a bit later on.
-Never let your gun run out of ammo, as soon as there is cover reload.
-Work as a team, you can only shoot one person at a time, so if two or three of you attack one person at a time you have a higher chance of success.
-You are not Chuck Norris, do not even try, you will fail.
-Make your shots count, don't just fire off your gun randomly, aim.
-Don't charge a group of enemies, doing so will result in failure, or death, possibly both, unless your gun has a high ROF (Rate of fire) and a lot of ammo.
-If you are going to pick up ammo off the ground, do it when there are no enemies around.
-Ambush your enemy while he is reloading.
-Use all available cover to your advantage.
1-40 of 324Next »
joefredbob2012 says: Apr 1, 2013. 1:52 PM
What pistol is in the top picture
jamesdude says: Jan 28, 2013. 4:39 PM
combat arms?
RangerStorz says: Oct 9, 2012. 1:54 PM
primary A: own design SR-35 Sniper rifle
primary B: own design AR-35 SMG
secundairy A: Desert Eagle
secundairy B: tactical knife with mini gun inside
as you may see: im a long range fighter :)
mrmuffin says: Aug 18, 2012. 6:58 PM
Primary a tr36 primary b Knex wasp secadary a my luger secandary b my mini mag fed pistol
moospoos says: Jul 2, 2012. 10:20 PM
Primary A: I_am_canadian's Heavy cannon V5 (Handheld)-
Because of the long range and moddabble ammo
Primary B: Dual mezak-
Because the ram rods cam hook eachother and you can then load em and shoot em!!!
Secondary A: My modded meZAK with removable clips-
Because i can then fast reload and it is pretty powerfull for its size
Secondary B: The break action shell ejecting double shooting shotgun thingy-
Nuff said
NE patsrock says: Aug 4, 2011. 3:49 PM
whait i thought this was by fred the peuinguin not dj radio
Fred the Penguin says: Aug 4, 2011. 9:03 PM
I posted it, but it was a collaberation between me and other notable knexers from this site including dj radio
GASSYPOOTS says: Feb 22, 2012. 3:48 PM
one more tactic... grenades grenades and grenade launchers :D
GASSYPOOTS says: Feb 22, 2012. 3:52 PM
mostly not frag but imploding ones
NE patsrock says: Aug 5, 2011. 6:42 AM
Oh
instruct39 says: Jul 29, 2011. 7:29 PM
Primary A- ZKAR v2 or BAW
i like the charging handle on the zkar v2 but the baw has removable mags
Primary B- any type of tr8
pretty much anything with a turret on the end of it is a good gun
Secondary 1- KLS v2 or BSW
BSW has better ammo for a war but the kls v2 is semi-auto with removable mags
secondary 2- TJOS or some other oodamo pistol
tjos has removable mags witch makes it better than most oodamo pistols, any other oodamo pistol would be sufficiant though
tytiger33 says: Jul 25, 2011. 10:01 PM
Here is a senerrio in a war. 2 guys stumble across a heavy cannon v1 with an enemy siting in front of it headphones in. The stand is only 6in high...  "Hey what is that. Looks like an arrow.  Yeah you're right. Or a.. I don't want to hear it. Is that an enemy in front of it? Yep, looks like he has headphones in. 'Checks the cannon' Looks like it it's loaded with one big round and 12 flat rounds.Giant shotgun? Yep. Well lets not let a loaded gun go to waste. On the count of 3 we pull the handle. But that could.... 1 kill... 2 him. 3 oh-well FIRE!" You see blood splatter over the gun and the enemy's upper body is nowhere to be seen. All that's left is what is below the muzzle of the gun. Both guys look at eachother, nod and run to the organiser of the war.They told him that they had found the guy like that. The war is shut down and the cannon's owner didn't want it back. So the 2 that caused the accident greedily took the parts and split them between eachother. They both had problems with any guns made with parts from that cannon, they always..... misfired when they were pointed at them selves unfortunenlety the first guns they made were NARs with 10 bands and sharpened ammo pointed at eachothers hearts.....
NE patsrock says: Jul 25, 2011. 2:08 PM
ik just a week a go i thought knex guns were stupid but now i know that they have WARS and fire RUBBERBANDS kinda like a airsoft gun war i luv airsoft wars but i got bannd idk y my dad said:(:(:(:(:(:(:(:(
beanieostrich says: Jun 24, 2011. 3:54 PM
LOL someone forgot the "L" in flag XD
dutch ghillie says: Mar 11, 2011. 2:03 AM
what is the name of the gun in picture3 step 8 on the bottom
Hiyadudez says: May 31, 2011. 12:26 PM
The ZKAR. But build v2
geodez says: Apr 6, 2010. 7:02 PM
(removed by author or community request)
tytiger33 says: Feb 7, 2011. 12:42 PM
Where can I find your "My Flak" and the "SlamFire"?
geodez says: Feb 10, 2011. 4:27 PM
My Flak is a compact shotgun I built, it is not posted but it worked similarly to the (now deleted) Oompa's Flak. The Slamfire is a compact oodammo pistol that is posted somewhere on Instructables.
tytiger33 says: Feb 11, 2011. 5:35 AM
Nope not there either.
geodez says: Feb 11, 2011. 5:06 PM
tytiger33 says: Feb 11, 2011. 5:30 AM
The Slamfire is Oddalumps so its not on Ibles I will check KI.
geodez says: Feb 11, 2011. 5:05 PM
I see.
rec0n says: Apr 5, 2010. 8:53 AM
TJSTR 2 is pretty versitile. and it shoots better than all of the other non-bolt action mag feds. shoots forther than my AR4- V3 ever did, too.
tytiger33 says: Feb 7, 2011. 12:34 PM
Where can I find the TJSTR 2?
DJ Radio (author) says: May 2, 2010. 9:16 AM
If you put all the mods I made on it on the gun, the AR-4 v3 goes around 70 with 3 bands.
silentassasin21 says: Apr 5, 2010. 11:17 AM
No it isnt i build it its a rather nonversitile gun.
rec0n says: Apr 5, 2010. 12:11 PM
How?
silentassasin21 says: Apr 5, 2010. 1:11 PM
It gets 40 feet in range then drops.
rec0n says: Apr 5, 2010. 3:11 PM
how many bands did you put on? mine goes 55-65 ft with 3 sets of 2 tied together #64s.
shimanto says: Dec 26, 2010. 10:43 AM
im the first subscriber at this page!!!
Dirtyboyy says: Sep 7, 2010. 6:19 AM
this is teh ultimate war gun
rookiebuilder says: Dec 19, 2010. 6:19 PM
Isn't that a Double TR-18?
Dirtyboyy says: Dec 22, 2010. 7:26 AM
yes, it is
KnexFreek says: Nov 23, 2010. 5:38 PM
Love it ^^^
instruct39 says: Oct 3, 2010. 12:06 PM
talk about a mutant of a gun! that is sick
geodez says: Mar 24, 2010. 7:20 PM
IT'S OVER 9000!
fauge7 says: Nov 24, 2010. 2:43 PM
tahts impossible
Merugop says: May 16, 2010. 9:48 AM
 What does the scouter say about his powerlevel?
Lol Ytp for ever
geodez says: May 17, 2010. 6:45 AM
1-40 of 324Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
