The popular option to consider is getting new transportation entirely. Both diesel cars and hybrids can get over 50 miles per gallon, which can add up to major money savings. I wouldn't recommend buying them unless you are already planning on buying a replacement automobile, as the cost will take a while to be offset by gas savings. Likewise, purchasing a motor scooter for short trips can save a lot of money if you make enough use of them. These scooters can get over 100 miles to the gallon, and are a blast to drive, so crunch some numbers using this calculator this calculator
The best options of course are to make better use of public transportation, walking and biking, but for many of us, these options don't fit well into our lives. With this in mind, I've assembled a list of tips and tricks will help keep as much green in your wallet as possible while still staying mobile.
If you like this article, please check out my website at http://www.rickywillems.com
Remove these ads by
Signing UpStep 1Steps 1 & 2 - Easing up on the Gas
There have been a lot of articles online about how to cut down on your gas consumption, but
hopefully this should have some new tricks, and a good list of old ones.
There are two genera of ways you can stretch the mileage of your vehicle. You can modify your car, or you can modify your driving habits. Obviously, modifying your driving habits requires less time, work and no money on your part, so I suggest you start there.
Smart Driving Habits
1: Slowdown Leadfoot!
This is the most off quoted of ways to save gas, but it deserves to be, as it's epically important. On highways, cars have a sweet spot for gas mileage. It's usually somewhere between 55 and 70. Experiment a little and see where yours is. If you don't know, and you have a newer car, 65 is a safe bet.
The common statistic is that every 5mph past 65 you go, you lose 3mpg.
http://www.instructables.com/files/deriv/FAY/910H/FKD1HMY6/FAY910HFKD1HMY6.MEDIUM.jpg
2: Accelerate Smart
Accelerating faster than you need to really kills gas mileage. You've got a speed limit anyway, so why race to get to that limit as fast as possible? Overall, it's how close (or how far above) that speed limit that's really going to make a difference in how fast you get somewhere, so speeding up faster makes a minimal difference anyway.
My trick for accelerating in a smart manner is as follows:
(I don't think you'll find this method anywhere else, so listen up)
- Get out on the highway, and once you're up to your cruising speed (60mph or so) look at your tachometer (that's your RPM gauge, as pictured. You may not have one, and investing 20 bucks or so in one might not be a bad idea). Look at your engines speed. This is all the power your engine needs to run at full speed, it's where your engine gets its best gas mileage, so you shouldn't need to rev you engine any higher than this in day to day traffic.
For one of the vehicles I drive, this RPM is 2100. I do my best to keep RPMs under this level. I
do this by not pushing as hard on the gas pedal, but also by momentarily letting up on the pedal as it approaches that speed. That lets the automatic transmission shift into a higher gear. If you have a manual car, simply shift when you get to this engine speed. For me, 50% throttle at 1200 rpm's uses less gas than 10% throttle at 2500 rpm's, experiment with yours.
Based on fuel maps from several common cars, this seems to often be the case. Also, short shifting is a way of limiting yourself from accelerating aggressively. If you keep yourself in a low gear until you need extra power, you will be more mindful of the extra fuel you're using to accelerate. Likewise, being in a higher gear reduces the "step on the gas and take off" result in pushing the gas, which tempts many a driver. Overall. it keeps you out of higher RPMs, which tend to use more gas compared to lower rpms, regardless of your throttle position.
Short shifting (shifting earlier than you otherwise would) is often helpful. If an engine is turning twice as fast, its pumping more or less twice as much air. In turn, your engine will be injecting more or less twice as much gas. Higher rpms are there to provide you with more power, if you need it. If you dont need the extra power, keep them as low as you can. (this is not applied in cases of downshifting manual engines, in which case fuel is often shut off entirely). Mind you, do not short shift to the point that your car feels bogged down and underpowered, as this is both inefficient and in the long run harmful to your car.
Just making this change to your driving habits can make a huge difference. I was a conservative driver to start with, and this still helped substantially.
A valid check would be a 5 tank average under what is your normal driving conditions. Run 87 for 5 tanks, then run 93 for 5 tanks, and see what the average is. When comparing things like this, keep as much the same as possible.
Im just pulling off a generic Toyota fuel map. (back calculated volumetric efficiency based on MAP readings, engine load, throttle position, ect)
VE at 1000rpm, 50% throttle = 71%
VE at 2500rpm, 10% throttle= 54%
to find the relative amount of fuel being injected (assuming all other factors equal), simply multiply rpm by VE.
710 at 1000rpm 50% throttle, 1350 at 2500rpm, 10% throttle.
710/1350=~53%,
meaning 1000rpm 50% throttle uses around half as much gas as 2500rpm at 10% throttle.
This is assuming certain other variables are constant, which is likely not the case, so this figure is an estimated example only.
Clean new engine air filter and a well checked tire pressure are mandatory as it results in my personal mileage, fuel, oil and filter changes database. Keep a hand or pedal air pump in your trunk it may help or even save a lot.
For instance, I have a little Citroen (diesel, 5 seats, 1992) in which I ride every day to university. Most is country roads, but include some city traffic and a few pedal-to-the-metal moments. I never went below 52 mpg (us gallons). Back in the 90s, an advertised announced a best of 64 mpg for this car. It held a record for economy until 2008, lost for a Peugeot HDI)
Cars that go below 25mpg are quite rare in Europe. They're either big luxury cars, US cars, or pre80's. Maybe because we rely on small blocks, I don't know....
You can always ask the attendant what the tank temp is, it is in a report they generate every time the tank is filled.
The tank temperature will change little over the course of a month, except when it is filled. In the winter, fuel after a fresh delivery, in the summer, fuel before. (If you know the patterns.)
The number 1 fuel economy fix I have found is to get a real time fuel economy meter. (Scangauge for newer cars, MPGuino for older fuel injected types.) You can instantly see what works and what doesn't.
