Step 2Steps 3 & 4 - Ease up on the Brakes
As you brake, you turn the energy of your moving car into heat. That energy comes from gasoline! If you see a stop ahead, let off the gas immediately. There's no sense using more gas to get closer to a line of waiting cars when you'll just be waiting there anyway.
To go a step farther, break just enough so that you will arrive at a light still moving as it changes. You vehicle uses the most gas to move from 0 mph to 10 mph. Avoiding a complete stop by timing lights correctly will really improve your mileage. Sometimes you can change a lane to avoid stopping, so do that whenever (safely) convenient.
Coast Down Hills and Up To Stop Signs.
To take things a step further, take your vehicle out of gear as you coast to a (almost) stop. This will let your engine drop its speed to idle, using less gas, and it will let you coast farther
without using any extra gas. The same thing goes for hills. Down a large hill, your engine becomes a drag on your vehicle rather than a power source. So shifting into neutral can let you car coast longer and faster than it would be able to when in drive.
(caution here, mis-shifting, shifting too often, or shifting while revving the engine can all cause undo wear and tear automatic transmissions. Use judgment, and make sure you're careful and practiced before you try this on large or busy roads. Also, if your vehicle has a steering column shifter, this can be difficult and you could potentially shift into reverse by mistake, so it is not recommended.)
::EDIT::
Wow Ive got the most feedback on this suggestion. Here is my reply.
Yes. Modern cars with manual transmissions -do- shut off fuel to the engine when costing in gear. This can save gas. You should keep your car in low gear when slowing down, and in high gear when on a steep hill if you would otherwise be using you brakes.
If you are coasting down a small hill though, or want to pick up speed down a hill, take your car out of gear! That gas you might save by keeping your engine in gear is very small compared to the gas you could save by not having to use the accelerator as much.
Looking at the tech-specs for some of my own vehicles, even under a relatively small engine load, I would have to have my engine out of gear for 12 minutes to make up for 1 minute of acceleration. In other words, I'm saving a fair amount of gas if I avoid accelerating by keeping my downhill speed up. Obviously this varies from car to car.
Use your judgment and experiment, but taking your car out of gear at appropriate times really can save you considerable fuel.
8
comments
Add Comment
Add Comment
