Step 3Steps 5 & 6 - Bad Habbits
Don't Idle
Idling in your car equates to 0mpg in your average. There's an old legend that starting your car takes more gas than leaving it idling. This used to have a grain of salt to it, but in modern fuel injected engines, it's not the case. Even idling for 30 seconds uses far more gas than starting your engine. The only hitch is that repetitively starting your engine adds additional wear and tear, so best bet is to avoid situations where you would need to idle entirely. Other than that, it's a trade off. (for my vehicles, If I'm planning on waiting any more than 2 minutes I turn it off)
Don't Carry Extra Weight!
If you own a van, and you don't normally use the removable rear seats, remove them until you need them. If you have a hundred pounds of stuff you've left in your trunk, clear it out. If you don't know how to or wouldn't want to change a spare tire (which you should know how to do) replace it with a can of "Fix-A-Flat" (a good thing to carry anyway). The rule of thumb is every 100 pounds dropped is another mile per gallon.
comments
Add Comment
Add Comment
