Step 5The Cone
I finally decided to use a sheet of UHMW polyethylene that I had kicking around, and just cover the outside with aluminum foil. I just didn't feel like using the aluminum panel I've been saving for an oil pan project.
First I used some software to determine the length of the cone based on what the exit opening was going to be and the opening of my feed-can. Then I drew that in Deltacad to find what the short and long radius needed to be to lay out a pattern on the plastic sheet.
The can is 83 millimeters in diameter, the exit diameter 242 mm, so that worked out to a layout radius of 4.5" & 13"
Using Deltacad, I figured that the amount of the layout arcs I had drawn, needed to measure 23" point-to-point on the outer radius. The plastic sheet just happened to be 23" wide, so I measured to the exact center of the sheet before drawing my arcs, and just drew them all the way to the edges. Not having any better tool, here I can be seen using a tape measure to make a mark every inch along the 13" radius. The 4" radius was drawn with a compass. Then I connected the marks and used scissors to follow that line. I took a close-up photo of the paper you can see in the background, that's my notes for this project. This will show what I mean about the dimensions of the cone.
what are the specs of it??
