this takes a lot of practice, but the most important factor in making items the same size is starting with the same amount of clay each time.
Not wanting to invest in a 100$ postal scale, or a 50$ food scale, I decided to make my own.
for little or no cost. (made from junk)
you will need
A peice of wood, a foot long chunk of 2x4 or even a peice of scrap plywood.
some baling or structuaral wire. In a pinch, Use heavy guage monofiliment fish line.
two containers roughly the same shape (I used 2 plastic coffee cans.) (actually in this picture, im usnig a misfired coffee mug as a weight, with screws in it)
a weight with a hole in it, (I used one of my cutting wires, but you could use a biggish Nut, or a fishing weight.)
tools: a drill (or somthing to make holes) , and a marker.
Remove these ads by
Signing UpStep 1Construction
one near the center close to the top,
and the other two in each of the lower corners.
attach a loop of wire to the center hole for hanging.
attach a loop of wire to each of the other two holes and attach the containers. in this expample, Im using a old mis-fired coffee cup and a large plastic coffee can.
Add Comment
