3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Country Pottery- Build a Extruder gun
A extruder is useful for making fast coils of clay, handles, and decorative parts.  most extruders come in two types, a wall mount (instructable in progress) and todays project, a easy and simple Clay Gun.
insers the prepared tube, fill with soft clay, and crank the handle....  just like a plydough machine....  on;ly more useful.....
this clay gun cost under 10$ and makes enough tubes for 3 diffrent die heads, though the parts are cheap enohugh to make a bunch.
Step 1
 the parts:
you will need:
a caulk gun frame- I picked up this one for 4.95 at the local hardware store-  this is a 13 inch gun, designed to use the "regular" sized tubes of glue and caulk
a length of 1 1/2 inch schedule 40 PVC Pipe, this peice is 5 foot long and cost $2.30
1 1/2 inch caps to use as die heads i bout 4 at 70 cents a peice
1 1/2 inch test cap  this was 35 cents for 2.
you will also need a marker, a hacksaw with a sharp blade and a mesuring device.
12 comments
Aug 11, 2011. 8:18 AMPotter John says:
Well, silly me. I didn't make a seal like you show; just the regular "pusher" from the caulking gun worked fine for me. I get very little blow by clay in use. But, clay probably works differently than some of the other things mentioned by others.
Jan 14, 2011. 11:14 AMthepelton says:
Neat! I may just build one to demonstrate my roller seals.
Dec 9, 2010. 7:23 AMOlivia says:
I love the idea of the interchangeable dies. This is so cheap too; I could never bring myself to drop the scratch for a "professional" one. Now I can make one with all kinds of crazy shapes. :)
Feb 21, 2010. 9:33 AMBigCountry says:
Hey moose, How about something like a can crusher for a wall mounted unit? You could cut you pattern holes in the side of the tube. Just a quick notion...
Jan 13, 2010. 3:45 PMstephenniall says:
anyone thinking of play doh right now !
Im going to use this with a small nozzle (made out of bic pen) for other things such as grease etc
Jan 13, 2010. 12:10 PMJobar007 says:
They do make empty tubes. They are for epoxy work on boats. See here:
http://www.jamestowndistributors.com/userportal/show_product.do?pid=2467
Jan 12, 2010. 12:56 PMlemonie says:
This will have plenty of uses, good stuff.
L
Jan 12, 2010. 12:21 PMElmundo says:
Nice Job!  I can see a couple of dozen uses for this thing, from grout to jerky stick mix....
Did you have any issues with getting a good seal on the plunger?  Some stuff out there really will try to get around a bad seal...especially if the desired outflow is small and creates backpressure...
I can see my forearm aching already from a day of squeezing out clay.  We'll have to figure out a way to make the plunger seal removable and adapt this for one of those battery/rechargable guns!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:Moose Gueydan
I am currently single, and have been a maker all my life. I currently work as a technician for a comercial Laundromat company. I and my friends have built a nascar simulator, and lot of other stuff, ...
more »
