iImage Information
We are The Crocodiles and this is our ‘bucket & chain’ style water pump. We are a group of Product Design Engineering students and were given the brief to construct a water pump which lifts 5 litres of water up a height of 600mm, in under 5 minutes, using the 24v motor provided. The winning team would be the one which completed this task in the most efficient way possible – voltage and amplitude were measured, as well as the total time taken. We decided that simplicity was the key and started work on a Bucket & Chain system.
Step 1Concept & Planning
iImage Information
After discussion, research and idea generation we came up with a concept for how we could make a bucket and chain pump that would fit the tank provided (pictured below). Our idea consisted of a simple wooden frame, two belts and five water containers – equidistantly spaced along the belt for maximum stability. One of the main features of our design was an adjustable arm that allowed the system to collect water at various gradient increments, meaning that it could be adapted to suit the water level of the tank. Here is a rendered image of our concept (made in SolidWorks):
http://en.wikipedia.org/wiki/Archimedes'screw
The screw is a great device, but is not as simple to build as you might believe. I think the author's KISS approach was great.
In my opinion it would have been way more efficient to get some garden hose and simply build some kind of rotary pump... In particular since you obviously had the opportunity to use a lasercutter.
Like this:
http://www.technolab.org/img/products/hako/Hako226.jpg
But nice work, nevertheless.
A series of bucket chains run from the sea up a cliff to a reservoir at the top and a turbine generates electricity in the usual hydroelectric way.
The sprocket at the bottom of each chain has a ratchet, and an arm connected to a large float.
The displacement of the float is slightly greater than the total weight of the water in all the full buckets going up.
The weight of the chain and buckets going up is balanced by those coming down, its just the water we have to lift.
If the waves are small, the chain moves slowly, but still pumps.
The turbines are switched off when the reservoir water reaches a lower set level on wind free days.
A spin-off is the seaside resort / seafood fish farm with no sharks at the top !
The reservoir could be a dam wall across the mouth of a dry arid valley, ( with no wetlands or vegetation to disrupt ) at the top of a cliff.
http://dinosweblog.wordpress.com/2008/03/26/energy-from-the-sea-the-pelamis-project/
