The Curiously Strong Trebuchet: A Pocket Sized Medieval Siege Engine by Ethanal
Featured
The Curiously Strong Trebuchet is a miniature trebuchet designed in a way such that it can be disassembled and stored in an Altoids tin. It uses standard materials like wood, threaded metal rods, and other hardware. It also uses common tools most every hobbyist would have in their garage. For these reasons, The Curiously Strong Trebuchet would be a great weekend project.
According to Wikipedia "a trebuchet works by using the mechanical advantage principle of leverage to propel a stone or other projectile much farther and more accurately than a catapult, which swings off the ground. The sling and the arm swing up to the vertical position, where, usually assisted by a hook, one end of the sling releases, propelling the projectile towards the target with great force."
My trebuchet is a bit different than some of the others that you see, in that uses a rubber band instead of a counterweight. I opted for rubber bands because they gave me better results with this particular trebuchet than weights and they are much more compact. This kind of siege engine is called a spring trebuchet, a form of a torsion trebuchet.
Here are some links, in case you want to get some more background info before you start:
-http://en.wikipedia.org/wiki/Trebuchet
-http://www.trebuchet.com/
-http://www.redstoneprojects.com/trebuchetstore/trebuchet_history.html
-http://www.tbullock.com/trebuchet.html
NOTE: The measurements in the steps ahead assume you are using an Altoids tin, or any other container of the same size.
GO TO STEP 12 IF YOU WANT TO SEE A VIDEO OF
THE CURIOUSLY STRONG TREBUCHET IN ACTION
Remember to vote for me in the Pocket Sized Contest if you like my Instructable!
Step 1: Parts and Tools
You will need the following in order to build the curiously strong trebuchet.
Parts:
X2 -#10-24 tee nut
X3 -#6-32 round head slotted screw
X3 -#6-32 machine screw nut
X2 -#10-24 rod coupling nut
X1 -#10-24 threaded metal rod (should be about a foot long)
X1 -Altoids tin
X1 -String
X1 -Cheerios
X1 -Rectangular stick of good quality wood (I used poplar)
X1 -An assortment of sizes and strengths of rubber bands
X1 -Straightened coat hanger or other wire
X1 -Standard rubber aquarium tubing (make sure that it's a snug, but not tight fit over the machine screws)
Tools:
-5-minute epoxy
-Tin snips
-Cordless/electric drill and drill bits (a cordless drill will suffice for most of this project, but an electric drill really speeds up some processes)
-Hacksaw/bolt cutter (again, a hacksaw will suffice, but a bolt cutter will work better)
-Scissors
-An assortment of pliers
-Dremel tool
-Vise
-Center Punch
-Oil
-Heavy hammer
-Coping saw
-Diagonal cutters
giike3 says: Jul 11, 2012. 11:55 AM
what is the diffrence between a trebuchet and a catupult? it looks the same?
Pettrocity says: Aug 26, 2011. 6:24 PM
AWESOME!!!!!!!!!!!!!!!!!
GrKe says: Jul 13, 2011. 3:27 AM
Man, seeing all of these altoids instructables makes me want to buy like a million tins. xD Thank you for sharing! I love trebuchets!
Burnsides says: Jul 8, 2011. 6:10 PM
NICE.
hyperactiveguy says: Jul 8, 2011. 1:26 PM
i saw this years ago when i had an altoids tin lying around. i meant to say what a great idea it was. although, the rubber band disqualifies this as a true trebuchet. I actually used fishing weights on mine to power it and can get about a 6 foot range under ideal conditions. Still great i dea
Ethanal (author) says: Jul 8, 2011. 2:20 PM
Yeah, I originally used a small weight too, but I wanted to keep it compact, so I switched to a rubber band. As you said, not a true trebuchet but it's still fun!
GianniMora says: Sep 27, 2009. 8:01 PM
i love your carpet... its sooo 70s
Ethanal (author) says: Sep 28, 2009. 1:32 PM
Its not carpet; it is just a spare piece of fabric.
viper64 says: May 27, 2011. 3:45 PM
its cool where did u get it
GianniMora says: Sep 28, 2009. 6:13 PM
oh... it still looks sweet. the 70's was a good decade, i wasnt alive but still good
abigscarytree says: Apr 23, 2011. 2:01 PM
how long are the machine screws and where did you get them. Also where do I find the rod coupling nut
(YOUR N says: Nov 25, 2010. 9:53 AM
please tell me you dont use cheerios in this
(YOUR N says: Nov 25, 2010. 9:51 AM
where do i get altoids tins
Crakur says: Jan 17, 2010. 9:45 PM
i wonder if you could set it up to collapse into the tin for transport...
Ethanal (author) says: Jan 18, 2010. 6:34 AM
It already does.  (read on in the Instructable)
Crakur says: Jan 18, 2010. 9:00 AM
Oh cool I didn't notice that.
ericmccloy says: Aug 2, 2009. 3:21 PM
This weekend, my son & I built this (with a few minor alterations). We had a lot of fun; thanks for the instuctions!
Ethanal (author) says: Aug 3, 2009. 4:08 PM
Your welcome. I love how you used wing nuts instead of tee nuts. Thanks for posting a picture. It is so neat to see other peoples interpretations of your project.
robotkid249 says: Jul 28, 2009. 12:37 PM
It's not exactly a Trebuchet, but good job!
Ethanal (author) says: Jul 27, 2009. 11:48 AM
Thank you to all who voted for me, even though I just missed getting into the finals. I hope you enjoy(ed) my instructable.
bowmaster says: Jul 26, 2009. 5:47 PM
I'm sorry to rain on your party but this is not a trebuchet. Trebuchets are traction or gravity powered. This is tension powered.
bleounis says: Jul 26, 2009. 2:37 PM
I would have loved to have this going through school. Sweet purple background, is that your carpet. I hope it is.
Ethanal (author) says: Jul 26, 2009. 4:45 PM
It's actually just a piece of fabric.
Ethanal (author) says: Jul 26, 2009. 5:42 AM
Remember to vote if you haven't already done so!
zaro12345 says: Jul 25, 2009. 11:29 PM
If I remember right, this is a simplified version of a traction trebuchet. In a traction trebuchet, people would pull on ropes to swing the short arm, thus hurling the object. http://members.iinet.net.au/~rmine/htt/ttspot.html
It is still a trebuchet, even if it's a different type.
Ethanal (author) says: Jul 26, 2009. 5:31 AM
That is exactly right. This is a simplified traction trebuchet.
coreyt says: Jul 25, 2009. 7:30 PM
This is pretty mint'(note pun intended).
standacrazytaco says: Jul 25, 2009. 9:19 PM
lol
Brother_D says: Jul 25, 2009. 9:02 PM
That's very boss.
MadBricoleur says: Jul 20, 2009. 6:56 PM
Intriguing. :)
Charles IV says: Jul 17, 2009. 7:28 PM
Um, technically this is a catapult... trebuchets use a counterweight to fling the projectile.
Ethanal (author) says: Jul 19, 2009. 5:05 PM
After some research, I confirmed that my creation is a trebuchet, not a catapult. A catapult uses a twisted rope or twine, or a piece of springy wood to propel the object. A trebuchet uses mechanical advantage and leverage to propel the object. Plus, a trebuchet has a rotating arm and a catapult does not. You are right that most trebuchets do use a counterweight, but not all trebuchets do.
rjnerd says: Jul 20, 2009. 1:25 PM
A catapult is a machine that can throw things. There are many kinds of catapult, some of which have specific names. If it uses a falling weight, its a trebuchet. If it uses a bundle of rope, its a torsion catapult. Spin? its centrifugal. Most catapults have at least one rotating arm (ballistae usually have two). All trebuchet use a falling weight. Sometimes its an explicit lump, attached to the arm, but there are "torsion trebuchet" that use the weight of humans attached to dangling ropes. Your machine uses a spring as its power source. It doesn't fit into the trebuchet subcategory.
Ethanal (author) says: Jul 20, 2009. 1:48 PM
This type of trebuchet is called a spring trebuchet (link).
myrrhmaid says: Jul 19, 2009. 1:32 PM
ADORABLE!
Tennis Fan says: Jul 19, 2009. 11:41 AM
This is awesome - really great job. I like all the detail.
Ethanal (author) says: Jul 19, 2009. 7:23 AM
Remember to rate my Instructable!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
