3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Curiously Strong Trebuchet: A Pocket Sized Medieval Siege Engine
The Curiously Strong Trebuchet is a miniature trebuchet designed in a way such that it can be disassembled and stored in an Altoids tin. It uses standard materials like wood, threaded metal rods, and other hardware. It also uses common tools most every hobbyist would have in their garage. For these reasons, The Curiously Strong Trebuchet would be a great weekend project.
According to Wikipedia "a trebuchet works by using the mechanical advantage principle of leverage to propel a stone or other projectile much farther and more accurately than a catapult, which swings off the ground. The sling and the arm swing up to the vertical position, where, usually assisted by a hook, one end of the sling releases, propelling the projectile towards the target with great force."
My trebuchet is a bit different than some of the others that you see, in that uses a rubber band instead of a counterweight. I opted for rubber bands because they gave me better results with this particular trebuchet than weights and they are much more compact. This kind of siege engine is called a spring trebuchet, a form of a torsion trebuchet.
Here are some links, in case you want to get some more background info before you start:
-http://en.wikipedia.org/wiki/Trebuchet
-http://www.trebuchet.com/
-http://www.redstoneprojects.com/trebuchetstore/trebuchet_history.html
-http://www.tbullock.com/trebuchet.html
NOTE: The measurements in the steps ahead assume you are using an Altoids tin, or any other container of the same size.
GO TO STEP 12 IF YOU WANT TO SEE A VIDEO OF
THE CURIOUSLY STRONG TREBUCHET IN ACTION
Remember to vote for me in the Pocket Sized Contest if you like my Instructable!
Step 1Parts and Tools
Parts and Tools
You will need the following in order to build the curiously strong trebuchet.
Parts:
X2 -#10-24 tee nut
X3 -#6-32 round head slotted screw
X3 -#6-32 machine screw nut
X2 -#10-24 rod coupling nut
X1 -#10-24 threaded metal rod (should be about a foot long)
X1 -Altoids tin
X1 -String
X1 -Cheerios
X1 -Rectangular stick of good quality wood (I used poplar)
X1 -An assortment of sizes and strengths of rubber bands
X1 -Straightened coat hanger or other wire
X1 -Standard rubber aquarium tubing (make sure that it's a snug, but not tight fit over the machine screws)
Tools:
-5-minute epoxy
-Tin snips
-Cordless/electric drill and drill bits (a cordless drill will suffice for most of this project, but an electric drill really speeds up some processes)
-Hacksaw/bolt cutter (again, a hacksaw will suffice, but a bolt cutter will work better)
-Scissors
-An assortment of pliers
-Dremel tool
-Vise
-Center Punch
-Oil
-Heavy hammer
-Coping saw
-Diagonal cutters
36 comments
Aug 26, 2011. 6:24 PMgnoseon says:
AWESOME!!!!!!!!!!!!!!!!!
Jul 13, 2011. 3:27 AMGrKe says:
Man, seeing all of these altoids instructables makes me want to buy like a million tins. xD Thank you for sharing! I love trebuchets!
Jul 8, 2011. 6:10 PMBurnsides says:
NICE.
Jul 8, 2011. 1:26 PMhyperactiveguy says:
i saw this years ago when i had an altoids tin lying around. i meant to say what a great idea it was. although, the rubber band disqualifies this as a true trebuchet. I actually used fishing weights on mine to power it and can get about a 6 foot range under ideal conditions. Still great i dea
Sep 27, 2009. 8:01 PMGianniMora says:
i love your carpet... its sooo 70s
May 27, 2011. 3:45 PMviper64 says:
its cool where did u get it
Sep 28, 2009. 6:13 PMGianniMora says:
oh... it still looks sweet. the 70's was a good decade, i wasnt alive but still good
Apr 23, 2011. 2:01 PMabigscarytree says:
how long are the machine screws and where did you get them. Also where do I find the rod coupling nut
Nov 25, 2010. 9:53 AM(YOUR N says:
please tell me you dont use cheerios in this
Nov 25, 2010. 9:51 AM(YOUR N says:
where do i get altoids tins
Jan 17, 2010. 9:45 PMCrakur says:
i wonder if you could set it up to collapse into the tin for transport...
Jan 18, 2010. 9:00 AMCrakur says:
Oh cool I didn't notice that.
Aug 2, 2009. 3:21 PMericmccloy says:
This weekend, my son & I built this (with a few minor alterations). We had a lot of fun; thanks for the instuctions!
Jul 28, 2009. 12:37 PMrobotkid249 says:
It's not exactly a Trebuchet, but good job!
Jul 26, 2009. 5:47 PMbowmaster says:
I'm sorry to rain on your party but this is not a trebuchet. Trebuchets are traction or gravity powered. This is tension powered.
Jul 26, 2009. 2:37 PMbleounis says:
I would have loved to have this going through school. Sweet purple background, is that your carpet. I hope it is.
Jul 25, 2009. 11:29 PMzaro12345 says:
If I remember right, this is a simplified version of a traction trebuchet. In a traction trebuchet, people would pull on ropes to swing the short arm, thus hurling the object. http://members.iinet.net.au/~rmine/htt/ttspot.html
It is still a trebuchet, even if it's a different type.
Jul 25, 2009. 7:30 PMcoreyt says:
This is pretty mint'(note pun intended).
Jul 25, 2009. 9:19 PMstandacrazytaco says:
lol
Jul 25, 2009. 9:02 PMBrother_D says:
That's very boss.
Jul 20, 2009. 6:56 PMMadBricoleur says:
Intriguing. :)
Jul 17, 2009. 7:28 PMCharles IV says:
Um, technically this is a catapult... trebuchets use a counterweight to fling the projectile.
Jul 20, 2009. 1:25 PMrjnerd says:
A catapult is a machine that can throw things. There are many kinds of catapult, some of which have specific names. If it uses a falling weight, its a trebuchet. If it uses a bundle of rope, its a torsion catapult. Spin? its centrifugal. Most catapults have at least one rotating arm (ballistae usually have two). All trebuchet use a falling weight. Sometimes its an explicit lump, attached to the arm, but there are "torsion trebuchet" that use the weight of humans attached to dangling ropes. Your machine uses a spring as its power source. It doesn't fit into the trebuchet subcategory.
Jul 19, 2009. 1:32 PMmyrrhmaid says:
ADORABLE!
Jul 19, 2009. 11:41 AMTennis Fan says:
This is awesome - really great job. I like all the detail.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Ethanal
Please subscribe, rate, vote, and comment.
