loading
Step 1: The templates
I have decided to use only PDF for the templates, many people seems exasperated as to how to open those EMS file using the free CAD program from eMachine shop. If you want them, put in the comments.
You need to print 1 copy each of Artichoke Branch and Artichoke Stem. 5 copies each of Artichoke leaves part 1 and part 2.
<p>Instead of written instructions, why don't you shoot a video while you make one? This way is would be even easier for us to understand and less painful for you</p>
I prefer anonymity
<p>Hi . <br>You brought me here (instructables.com)<br>I want to say thanks for your ins . This lamp i made 2 years ago , with light effect -changing colors. </p>
Hi there!<br><br>I really liked this tutorial (I have a soft spot for lamps) and I decided to feature it on my website. You can see the page here:<br><br>http://lescreateliers.com/Les_Createliers/Idees_Ideas/Entries/2011/9/29_Lampe_artichautArtichoke_lamp.html<br><br>If, for any reason, you do not wish to appear on my website, just let me know and I'll remove my post right away!<br><br>Cheers!<br>Marie-Eve
Oui oui! Sez free!
What thickness polypropylene is best? And has anyone got any links to online stores (preferable UK based!)?<br><br>Do the triangles with the greater angles (i.e. the ones less like triangles) go with the bigger leaves or the smaller ones?<br><br>Thanks
The one I use is 0.35mm about 3 sheet of printer paper thick, in UK, Paperchase is where I brought mine, frosted polypropylene 500x600mm, &pound;1.75<br><br>Yes the bigger angle goes with the larger leaves, the angle gets smaller with the smaller leaves, kind of logical, note there are 2 set of leaves that are the same size.<br><br>You can play with the shape of the leave, palm leaves? Ferns? Square?
Hey nice design. I will see if I can do that out of a square paper as well. J<br><br>For those too lazy to view the documents and images and read your along annotations here is a quick step by step as I picture it:<br><br>0&gt; Print out the four documents, 1x stem, 1x branch, 5x leaves part 1 and 4x leaves part 2. Get the mentioned plastic sheets in your flavour.<br>1&gt; cut out everything on the sheets and create the marked holes.<br>2&gt; take the small fans on a leave and fit them both through the middle of one of the connectors from the sheet called branches. Repeat this step for all other leaves left on your table. (see picture three)<br>3&gt; roll up the stem to slot in the branches/connector-thingy into your stem. (see the last picture). After you managed to fit in the next leave, connect them together with a paper clip through the holes in the overlapping leaves. Repeat this around and up the stem until your lamp looks fancy enough.<br><br>Cheers,<br>is no DIY
Heh, thanks for the extra explanation, 100% agree, it is easier to see what's happening with the print outs.<br><br>But of course all comments 101% welcome!
Definitely needs notes. Soooooo confusing just in pictures. Find myself thinking &quot;how did she get THAT out of THAT?&quot;
Very nice. I am going to try this. I think they would be beautiful around the yard for the Grandkids or me to follow at dusk. Thanks again
Thank You! Enjoy!
Instead of complaining, someone who likes writing could help add to this, corrugator supercilii obviously is not that way inclined... (maybe i should volunteer... and i might. I'll just work from the pictures till i've done it all and write instructions along the way.) I think this is a bloody beautiful design and my fingers are itching.
Hi, <br><br>Glad you are keen to give it a go... I do have 8 other instructables posted, some of them are quite long and detailed, but my observation is, most like to just browse through the steps, enjoy the creation process (like me), maybe learn a few new trick... Few actually get their hands dirty.<br><br>When you see the print outs, and compare it to the photos, it would be clear what's going on.
Smorgenster: it would be wonderful if you made instructions to this. my room really needs a new lamp :)
I'm wondering what type of light source you used?
Yea, good point... Forget to mention...<br><br>It is sized with a diameter of 60mm, such that you can use a small wattage golf ball fluorescent lamp (7w, E14, the one smaller than the regular 60w screw). <br><br>Hence you can use a suitable lamp based, e.g from Ikea, and top it like a lamp shade, it should sit very nicely.<br><br>DO NOT USE INCANDESCENT, fire risk really...<br><br>
Thank you so much. :)
FYI for those not in the UK most dollar stores here in North America sell plastic sheets like this as cutting boards, the often come in other colours too so you could be even more creative if you want ;) In fact I've used them in one of my instructables now that I think of it, <a href="https://www.instructables.com/id/Yet-Another-Flash-Diffuser-designed-for-a-Canon-5/#step1">here's what they look like.</a><br> <br> Cheers<br>
This will be a good instructable when it is finished.
Pwarh! Tough crowd dude!<br><br>
It would be exceptionally helpful, for those looking at your photos, if you could include some instruction on what was happening in said photos. Also, the next page should be a separate instructable. Instead of including the table mod, you could clarify what is happening in this instructable.<br>Thanks!
I find knitting code incomprehensible too! (^_^)
not writing out full instructions is fair enough if you must, but you really need to add some annotations to the pictures
Oh, you are naughty. Beehive!<br><br>(Best said in a Kenneth Williams voice. Or possibly Austin Powers if you have the misfortune not to know of Kenneth Williams.)<br>
Artichoke Lamp looks like a lotus to me
Sure! It's a nice Lotus Lamp. :)
Yes, I would agree, heh (^_^)
About This Instructable
48,318views
385favorites
License:
More by Corrugator Supercilii:Convert Xiaomi NightVision Wireless IP Camera to a remote Door Viewer The any value Joule Thief - Single AA high power white LED driver Improved GorillaPod Helping Hands Tool
Add instructable to:
