Step 4Nail the Two long sides on to the top piece
iImage Information
as simple as it sounds this part was actually a little bit hard... i used some bent pieces of sheet metal and some clamps to do it myself.. but you might be able to do it with a pair of helping hands... good luck. Use the images for referance... also because of the thinness of the wood you have to use a drill to make the holes slightly smaller than what you will be nailing in... and make sure your nails are short enought that they wont crack the wood... this is dificult because the wood is thin so take your time... (you will most likely need to shorten your nails by clipping them... i did it as a precaution.)
