The DON Stove - Alcohol Stove by wiley coyote
Featured
The Durable Obvallate Nemophilist Stove
..... or it could just stand for my name.
** Don't do this!  There are sharp edges and you may get hurt. **
I wanted to make an alcohol stove that was durable, versatile, used no chemical sealants, and was made out of readily available recycled materials and this is what I came up with.
It is a double walled, can stove, made from two cans.  The exterior can (top) being an aluminium soft drink can bottom, and the interior, a soup can bottom.  I chose a soup can because of it's diameter, strength, and the ridges in the side of the can.  The ridges provide rounded edges for the aluminum can to stretch over and seal against.
The stove body construction, itself, is the main reason for this Instructable.  I have included a couple of stove designs and accessories for ideas.
BONUS side effect..... perhaps - The base if ferrous and will stick to magnets, which may be useful for storage or securing it in place, in a wind screen type setup.
Step 1: WHAT YOU NEED
1 each 284 ml/10 ounce soup can
1 each 355 ml aluminum soda pop can
1 each felt tip marker for marking cuts and holes
1 ea pair of crappy scizzors (what I use), or other device, for cutting cans
Utility knife if req'd
1 ea thumb tack, or similar device, for poking holes.
Drill bit, or other device, for enlarging holes as req'd
Tomdf says: Jul 14, 2012. 11:57 AM
Check it out, I made one! Now, forgive my ignorance, but what kind of alcohol should I be using in this? Rubbing alcohol just blows itself out, and Wild Turkey doesn't do anything at all!
schreibwy says: Dec 9, 2012. 9:03 PM
Ethanol. Everclear or Heat that comes in yellow bottles. Also denatured alcohol.
wiley coyote (author) says: Jul 26, 2012. 12:58 AM
Excellent! I use methyl hydrate and it can be found in the paint thinner section of any hardware store.
anchorsandships says: Jul 16, 2012. 3:00 PM
isopheric will probably work the best its 92% and like $3.00 at target
EvilbunnySurvival says: Oct 30, 2012. 7:16 PM
Would you be willing to sell one?
Andsetinn says: Aug 8, 2012. 7:49 AM
This is nice. Good idea with the soup can. Most alcohol stove designs I've seen use 2 soda cans that can be tricky to put together. The problem (for me) is getting the right alcohol.
huck alexander says: Jun 28, 2012. 12:09 AM
Wonderful instructable, wonderful photos! Being a bit naive here, but what is the temperature range of a stove like this? I have immediate need for such a stove, and thanks to your guide, have found use for some of the trash my wife tells me I'll never use and should get rid of.
This is a great idea for those of us obsessed with repurposing rather than recycling!
Thanks for sharing your creation!
wiley coyote (author) says: Jul 11, 2012. 9:40 AM
Thanks and you're welcome. Repurposing is my obsession.
I have no idea of the temperature range as I'm just a beginner, messing around, and wanted a slap together anywhere stove body, using minimal tools.
Schooniedude says: Jun 27, 2012. 11:56 AM
Nice work. I have learned a lot about alcohol stoves this summer yet you still taught me new things. Great job.
wiley coyote (author) says: Jul 11, 2012. 9:30 AM
Thanks. I'm just a beginner myself.
lothar1511 says: Mar 20, 2012. 9:24 AM
Really nice design but i noticed that the stove wasn't as hot as some of the other stoves iv made in the past so i added a Inner Wall works like a charm now thanks for the more durable stove
wiley coyote (author) says: Mar 31, 2012. 3:29 PM
You're quite welcome.
I'm glad someone who might have more use for it than I, took it and ran with it. I had to get it outta my head and down on.... ummm..... not paper.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
