One nice feature of the TLC5940 is that it is daisy chainable, which means that one chip can be connected to the next one and so on for plenty (500+)of pwm ports. Each one of the ports is individually controllable from only using 5 pins from the microcontroller. This creates great possibilities like creating low resolution screens or light patterns which is fully customizable and so on. Also control of motors and other outputs is possible.
In this Instructable I will show how to solder the breakout board and also how to connect it to an arduino and control leds.
The kit with the pcb and everything else needed can be purchased at http://blushingboy.org/content/dawm where also many other open source projects are sold.
The datasheet for the TLC5940 can be found here with all the specs http://focus.ti.com/lit/ds/symlink/tlc5940.pdf
A library for controlling it from arduino can be found here http://www.arduino.cc/playground/Learning/TLC5940
Since this is my first Instructable I would love comments on it...
Remove these ads by
Signing UpStep 1Material and tools
1 The Dawm (breakout board) available now by mailing me or soon from here http://blushingboy.org/
1 TLC5940 available as an sample from Texas Industry for free or from Digikey (Digi-Key Part Number 296-17732-5-ND ) or similar vendor
38 female pin headers (not necessary but makes life easier)
1 resistor which size depends on the current you are going to be using. (more about that further down)
Soldering iron
solder
plier
I'm in Wisconsin (54124).
Thanx.
Dan
