3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Dearthbox: A low-cost, self-watering planter
Step 3Cut the holes in the buckets
Cutting plastic kicks up a lot of little plastic dusty bits. Protect your eyes and nose and mouth accordingly.
For the big holes on the first bucket and the lid, start them with a drill, using a 1" masonry bit. Use the utility knife to widen the holes.
Cut drainage holes in the bottom of your first bucket, using a 1/4" diameter drill bit.
Next, cut the side drainage holes on the second bucket.
Remember, do not cut the side drainage holes in the bucket with the holes in the bottom.
You can smooth the edges with the file if you want.
Note that I don't have a picture of this process for the bucket lid, but you want to do the same thing for the pipe hole and the plant holes you marked in step 2 on the lid.
4 comments
Feb 9, 2012. 9:41 PMnevroth says:
For the bootleg people like me, you can heat a phillips screwdriver on a stove (that's on, obviously, lol), and then stab holes into the plastic. I anticipate using a flathead to make a larger circle, and just stab around the circumference. Worked like a charm when I recycled some kitty litter tubs into planters. Unfortunately I used both as planters, but I might buy two more just for the opportunity to convert to self watering tubs!
Mar 27, 2010. 2:37 PMmerideth says:
it's not a masonry bit it's a spade bit...worked great for me...fantastic project!
Aug 6, 2009. 5:35 AMjeff-o says:
An even better bit to use is a "hole saw" which will drill holes 2" in diameter and beyond... expensive, though.
Jun 20, 2009. 8:29 AMgregr says:
Why are you using a masonry bit?
Jun 20, 2009. 8:52 AMstephenniall says:
metal bits or Wood bits if they have the sharp bit at the front will shatter the plastic
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:lindsaytorte
