3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Dearthbox: A low-cost, self-watering planter
Step 5Assemble the wicking basket
Either line the drain grate with mesh, or cut holes in your solid plastic container. We found these as a three pack at the dollar store. You could also use food containers, etc., as long as there is enough of a lip and they are the right height.
Even though it's significantly more expensive, I highly recommend the drain grate option. They both seem to be performing equally well, but the drain cover just seems sturdier and better.
The last photo is of the wicking basket with dirt inside already. You don't have to do that part yet, but this shows you how the netting helps contain the dirt.
1 comment
Jul 9, 2011. 5:50 PMinalak says:
Another good thing to use instead of the mesh from the garlic is a paint strainer bag from a hardware store. They are only around a buck each have a finer mesh so I think less soil will be able to get through. The small paint strainer is about the size of a small can of paint. My girlfriend and I have been using the 5 gallon size to cover our basil as we've had an onslaught of leafminers. Obviously the 5 gallon size is a little more expensive but only by about a buck more. Great work on this btw. Much mahalo for this instructable
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:lindsaytorte
