13, 2:07 PM.jpg
This Is a fun prank you can play on any soda drinkers. The main idea is that when your friend opens up a can of soda there is nothing inside. This prank is very simple and only takes a few minutes.
Step 1: Supplies
13, 6:48 PM.jpg
For this instructable you will need a hammer, a sewing needle, a soda can (full) and a glass
joey99 says: Mar 14, 2013. 1:25 PM
woldnt they notice how light it is???
bird123457 (author) in reply to joey99Mar 14, 2013. 11:44 PM
I can see where you are coming from. If you are concerned then you could add salty water through a syringe, then they would have a real surprise!
bajablue in reply to bird123457Apr 9, 2013. 3:57 PM
That's what I was thinking. JB weld could be used to close the hole and it wouldn't leak. >;-D
MR.Geo says: Mar 23, 2013. 5:01 PM
If I were pulling this prank, fizzy lemonade would be my substitute of choice for cola. This would seriously mess up my flatmate. So confusable when he has a hangover.
Mr_o_uk says: Mar 13, 2013. 2:46 PM
Instead of 1 hole in the middle, If you put 2 holes, one at either edge, it will be a lot easier to get the liquid out as air will go in one hole with the liquid coming out the other.
bird123457 (author) in reply to Mr_o_ukMar 23, 2013. 4:32 AM
Wow, how interesting!
zews says: Mar 14, 2013. 6:15 AM
doesn't hot glue not stick to metal very well. especially wet metal.
bird123457 (author) in reply to zewsMar 16, 2013. 2:08 AM
Depends on which glue you are using, I tried this again and I chose a silicone sealant I bought at the dollar store.
zews in reply to bird123457Mar 18, 2013. 7:21 AM
i tried epoxy(epoxy fix's everything right) but it still didn't stick for long. when i put it in the fridge dew drops formed on it and loosened the glue.
bird123457 (author) in reply to zewsMar 20, 2013. 10:56 AM
If you are having problems I highly recommend a marine sealant, these glues are made to be super strong!
przem says: Mar 13, 2013. 2:56 PM
Simple yet funny - I like it!
You can refill the empty can (using syringe and thin needle) with salty/acid water. It will provide proper weight of can and an (unpleasant) surprise after first draught. The hole can be sealed with hot glue, wax or sth. similar.
Best regards and keep pranking!
P.
bird123457 (author) in reply to przemMar 14, 2013. 12:01 AM
What a good idea! Thank you for sharing!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
