iImage Information
DNA models have been made from a lot of different things; candy, Styrofoam, KNEX, etc. I've even made a couple of models myself from beads, but surely there should be a model made from LEDs....
Step 1What you will need:
iImage Information
Materials:- Base or stand -I used a dollar store jewelry box made of wood.
- LEDs -5 different colours 20 total,8 white and 3 each of the other colours.
- The appropriate resistors.
- Power supply, with enough voltage to power the circuit (I used a 9v adapter).
- Wires -white preferably
- Electrical tape -white preferably
- On/off switch.
- Floral stem wire (18 gauge)
- #6 plastic (polystyrene) -it is the clear plastic often used in takeout containers.
- Clear vinyl tubing ~2 feet long, 7/16 inch diameter.
Tools:- Soldering iron, solder etc.
- Scissors, and X-acto knife.
- Drill, Dremel
- Sandpaper
- Glue (Weldbond)
- Toaster oven, oven mitt and parchment paper
Penolopy Bulnick was wise to use your ible as the main image for "Teaching Tools: Biology Edition" as it sure got my attention. :D
Great job.
-there are 10 nitrogenous base pairing every one full turn of the double helix.
anyway, nice work.. :)
well, in mexico that grade translates to 10 ; )
first pic is the chain, second pic shows nitrogened bases, and third pic is both at the same time, i putted 2 buttons to switch betwen ligths!
anywaz, thanks a lot man!!!
:D
it's really very nice
could you send me the diagramm that you used to the conections??
i'm just learning about leds and i'm not very good.
however i wanna try to make this project
thank you and congrutalations again
my e-mail adress is lobo.alirog13@gmail.com
And want your cat is beautyfull , ;)
I wonder how hard it would be to wire up the hydrogen-bonds with small pin connectors (like Burndy's) so that the LEDs would only illuminate when complementary bases were joined. This would make a really cool kit...
