Remove these ads by
Signing UpStep 1EMP and what it is.
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
Different portable radio sets (walkie talkies) were tested, for one thing. The first-generation transistor sets (the PRC-77) were found to have the best survivability. They held out when even tube (PRC-6) and hybrid (PRC-25) sustained EMP damage. The early types of Germanium transistors that were used in the PRC-77 were overbuilt (and also very inaccurately manufactured, but that's another story) and so were hardy enough to withstand EMPs. Todays Mosfet and CMOS technology is extremely fragile, when it comes to EMPS.
The knowledge gleaned from the military tests of the 1960s led to the development of "military-spec" IC chips, which, in theory, should also be able to hold up fairly well. But the best bet, aside from lining the walls of your home with steel mesh, and hoping for the best, (and not having your family send you off to the loony-bin) is to have an old PRC-77 handy as a survival set.
So make sure the joins between walls of your faraday cage are bonded electrically all along the edge.
So to be really effective against EMP, which is very wideband by nature, you need to get some of that conductive gasket material to seal all the way around the doors.
I've made a small faraday cage with an old metal shelled cooler. I covered the non-metal portions with copper flashing (10 inches wide from the hardware store and soldered along the edges), riveted every 2 inches to the steel body with stainless steel rivets. Aluminum rivets don't work well because they form a highly insulating layer on contact with air, within seconds.
google VLC, it's sweet stuff we're starting to use here in St. Cloud Mn.
Cheers
I mentioned building a small faraday cage in another reply, I've also stuffed iron wool in it as an absorber.
Of course, how you build it and how or whether or not you ground it depends on what exactly you are trying to accomplish. My faraday cage is just meant to cut way down on the signal going in and out in order to cut the range of a particular piece of equipment down so that more than one person in a building can test the 2 way comms of this equipment. So I'll actually have a sliding window in mine in order to adjust the shielding.
To my knowledge, and emp is an emp. It will travel through metal, traveling long distances through the power grid.
