Boot up your Xbox without a game in the drive then go to memory. Make sure your thumbdrive is plugged into the controller or otherwise connected to the XBox. Your XBox will say that your thumbdrive is not working correctly and has been erased (i hope you didn't have anything valuable on it!). After this, simply plug that sucker into your computer. when the PC identifies the drive, it will ask if you would like to format it. Don't! Install Xplorer 360 to the desktop and as well, extract the NTSC folder within the compressed folder to the desktop as well. then start X 360 and go to >Drive >Open >Hard Drive or Memory Card. It will identify the thumbdrive as Partition 0 (the thumbdrive has been formated by the XBox as FatX so your PC will not recognize it on its own). Now Drag 'N' Drop the four folders inside NTSC to the right hand of the X 360. This will take about 15 minutes or so as the files aren't simply copied, but 'injected' onto the thumbdrive. So crack a cold one and throw on something to pass the time (it was Hulu for me :D and yes i am in Canada, but i know a way around that ;) )
However, when I download your SID file, there is no NTSC folder, and when I go to load a game in Splinter Cell after copying your SID folder to my USB Stick, There are no save games.
Could you provide a little further clarification? Thanks!
Also I'm using a 2GB Kingston Datatraveler to transfer files from my computer and everything works fine if my computer is writing to the card, but if the Xbox tries to save anything to it, it comes up with Error 0. Does anybody know what that's about?
Please help.
(The drive is 2 GB, FAT32, and write-protected)
http://www.instructables.com/id/Softmod-Original-Xbox-Without-Action-Replay-Cover/
There's a picture of the drive I used in that link, just scroll a little bit. Their pretty popular nowadays so I would use that one.
itl be the only drive in the list on the left, since Xplorer360 exists only for FATX purposes
I wasn't running the newest version of Xplorer360.
http://www.xbmc4xbox.org/wiki/index.php?title=USB_Mass_Storage_support_in_XBMC_for_Xbox
you can find cheaper ones on ebay as well.
I opened xplorer360 (beta 6 I believe)
Clicked Drive>Open>Harddrive or memcard...
Partition 0 showed up on the left hand side
I right clicked Partition 0 and clicked Extract
I then extracted a folder onto my desktop that was named Partition 0 (it was empty)
I then took the NTSC files and draged-n-dropped to the right hand side of xplorer360 them per the instructable and they began injecting to the jump drive.
I used a sandisk cruzer 2 gig jump drive with the U3 partition removed.
I also found this list of compatible jump drives:
http://wiki.xbmc.org/?title=USB_Mass_Storage_support_in_XBMC
Hope that helps!
Help me please ?!
