loading
Step 3: Copying Files From Stick to XBox
Once the Files have completed injecting onto the stick, you can now plug it into the XBox. You will want to access the Memory section of the Dashboard, then select the area where the thumbdrive is recognized (in the case of my install, it was Controller One). You will want to open that part, then press Right (->) on the D-Pad on the controller then copy the appropriate save file to the hard drive (in this case, The Splinter Cell Linux save). Now this will take a while again to copy, so its good to have something to do. This should take about ten minutes (blame the USB 1.1 connectivity of the XBox). when this is done you can check the hard drives contents in the Memory Section to confirm. When this is done, exit all that then remove the thumbdrive. Now load your Game and on to the next step!
<p>Just thought I'd add a comment as I softmodded my original xbox last night and used this guide as a basis. Obviously things have changed a little since it was posted but overall this was a good guide. </p><p>Firstly, I struggled to find a flash drive that would be recognised by the Xbox. I think everything I tried was probably too new (USB 3.0 drives) or too large. I found an ancient 128mb flash drive that was detected ok but that was too small for the exploit to copy on to. In the end I used an old 512mb memory card plugged into a USB Card reader and that was detected and erased by the Xbox fine. </p><p>Secondly, the download link for the softmod installer was no good for me, I think it only has part of what you need. </p><p>I googled for &quot;Splinter Cell soft mod NTSC&quot; and eventually found this site that had the files I needed and a little more detail on which ones to copy onto the flash drive. <a href="http://www.theisozone.com/downloads/xbox/tools/sid-512/" rel="nofollow">http://www.theisozone.com/downloads/xbox/tools/sid...</a></p><p>Otherwise everything else is much the same, use Xplorer 360 to &quot;inject&quot; the files onto the flash drive, copy them over to the xbox hard drive and then load up Splinter Cell or whichever game you're using and load the same game from the hard drive. </p><p>Next up I need to get a bigger hard drive in there and also get some emulators copied onto it! </p>
<p>Thanks for the update.. Is Splinter Cell absolutely required? I have Halo 1 &amp; 2, NFS Hot Pursuit, and Counter-Strike. Would any of those work?</p>
No, I'm pretty sure you need either Splinter Cell, Mech Assault or 007: Agent Under Fire. <br><br>I was able to pickup a boxed copy of Splinter Cell for five bucks from a store near me recently and I think it's the easiest one to find out of the three.
<p>Thanks for the info! :)</p>
<p>What should i do ? please tell me step by step</p>
So everything seems to work fine until I try and &quot;inject&quot; the folders to the thumb drive. x360 says its injecting but nothing happens. I've tried using the x 360 and x 360 beta 5 with both vista and win 7 in compatability mode. Do you have any other suggestions on how to get the files onto the thumb drive?
Hey man. I was having this problem too. I ended up using my old computer that is running Windows XP. I was still having trouble with xplorer360. I could get &quot;partition 0&quot; to show up but the files weren't &quot;sticking&quot; to it. This is how I got it to work (somehow haha...):<br>I opened xplorer360 (beta 6 I believe)<br>Clicked Drive&gt;Open&gt;Harddrive or memcard...<br>Partition 0 showed up on the left hand side<br>I right clicked Partition 0 and clicked Extract<br>I then extracted a folder onto my desktop that was named Partition 0 (it was empty)<br>I then took the NTSC files and draged-n-dropped to the right hand side of xplorer360 them per the instructable and they began injecting to the jump drive.<br><br>I used a sandisk cruzer 2 gig jump drive with the U3 partition removed.<br><br>I also found this list of compatible jump drives:<br>http://wiki.xbmc.org/?title=USB_Mass_Storage_support_in_XBMC<br><br>Hope that helps!
Hey, Thanks alot for this, it really helped . I kept dragging the files over in xplorer360 , they said they were injecting but nothing was showing up on the card. <br> I then tried what you suggested above &quot; right clicking on Partition 0 and clicking Extract, then extracted a folder onto my desktop that was named Partition 0 (it was empty) <br> then taking the NTSC files and draged-n-dropped to the right hand side of xplorer360 them per the instructable and they began injecting to the jump drive.&quot;&quot; <br> It worked perfectly Thanks alot!!:))
<p>Try this with modding xbox 360 software very simple steps <a href="http://www.moddingxbox360.blogspot.com" rel="nofollow">www.moddingxbox360.blogspot.com</a></p>
same problem here :( says it's injecting (takes 1-2 seconds) then doesn't show up in explorer360 or on the xbox?
has to be injected for this hack.
<p>Hi! I want to do this to run classic console emulators, like NES, Super Nintendo, Sega Genesis, etc. How do I install the emulators and roms? do they run from the USB thumb drive or can I burn them into a dvd that runs in the xbox?</p>
<p>Which Usb drives plus does it have to plug into the memory slot or can it just plug directly into the xbox</p>
so i have the files on my xbox, and the Linux save shows up when i run splinter cell, but when i try to load it nothing happens. it just sits on the screen where you select check points or levels. help please???
Idk if this is what I was looking for but I had this guy do something to my Xbox and he put tons of classic games . well he said to press some buttons to get it going . anyone know what I'm talking about? Help .
<p>you got your xbox mod-chipped by him most likely</p>
<p>ok I have updated dash and formatted 4gb sandisk cruzer edge with the xbox original and have put it in pc I didn't see no message about formatting the drive although it installed a driver for the cruzer edge. my computer don't show the drive but it shows in device manager. I right click on xplorer360 and select run as administrator I select open hdd and get a message can't find fatx drive. I'm using windows 7 </p>
<p>the xbox itself formatted the cruzer edge so it says memory unit 2a just to make that clear</p>
<p>i have a modded xbox but now the screen want get off of the starting menu and want play any games how do i get it to work again</p>
<p>so after i hack the box... where am i putting my emulators and roms to play them because they wont show up after i FTP them into a Folder in E:\\games</p>
How recent is this thread? 2014??
<p>Just looked up stuff does any usb work or just compatable ones?</p>
<p>Also can I use a action replay pro as the also does it have to be a thumb drive or can ut be a regular flash drive</p>
<p>I have a PAL Xbox, is there a PAL folder?</p>
The softmod install files: (scanned with Comodo and safe)<br>http://www.1337upload.net/files/SID.zip
These files do not match up with the tutorial. How can these be applied to the walkthrough? Do you have any more information? Feedback would be appreciated. Thank you. :)
<p>I have the same issue! Nothing I do with these files works. Once I get the files copied to the thumbdrive and bring it up in the XBox all i can do is Delete the &quot;corrupted saves&quot;</p>
thanks friend. i will put them in the tutorial :) much appreciated. been rather busy these days and havent gottena chance to do it myself!
how do u get a usb drive hooked up to a Xbox controller I cant get it to go it there like it shows in ur pictures.
This walkthrough did the job. Hope it works out for you. I used epoxy for mine rather than silicon. <br> <br>https://www.instructables.com/id/Original-XBox-Controller-Memory-Card-Slot-USB-Conv/?ALLSTEPS
hi all i was wondering if this mod will work on a pal model as it would be good to get the old xbox doing something again many thanks
I have 2 problems: <br> <br>1: There is no NTSC folder in the zip. I have a SID folder &amp; a folder with a bunch of numbers for a name. <br> <br>2: My xbox recognizes my flash drive as a memory card but I can't get xplorer360 to find it. <br> <br>Thanks,
Yeah same problem here as bripilot. the file doesn't have the ntsc folders?<br>Is it not the right file or maybe just a part of it? If someone could send me the right files to me that'd be sweet!<br><br>Thanks!
In your tutorial, you say to &quot;Now Drag 'N' Drop the four folders inside NTSC to the right hand of the X 360&quot;<br><br>However, when I download your SID file, there is no NTSC folder, and when I go to load a game in Splinter Cell after copying your SID folder to my USB Stick, There are no save games.<br><br>Could you provide a little further clarification? Thanks!
ya same thing<br>
Can files be transferred, between the Xbox &amp; computer, via the &quot;Controller to PC / MAC USB Cable Adapter&quot; on an Xbox controller with memory card?
the memory card is no good, as it is only 8 megs and this mod requires much more space. the cable adapter is more recommended, if you cannot mod your controller as i show in the other tutorial i have (puts a usb female port in place of one of the memory card slots)
Hey, I've gotten the softmod to work about 90% correctly. I'm using UnleashX and I can't get it to save the skin I want it to use after a reboot. I don't know what that's about. <br>Also I'm using a 2GB Kingston Datatraveler to transfer files from my computer and everything works fine if my computer is writing to the card, but if the Xbox tries to save anything to it, it comes up with Error 0. Does anybody know what that's about?
if you have hacked the xbox successfully, try using FTP to transfer files between pc and xbox. its easier and less of a headache. Filezilla and FlashFXP are two good programs
Where can I get hol of the CNG-Xbox-Softmod-Pack? As the megauploa link is dead now.
Your links to get the Xplorer 360 and softmod install files don't work anymore. Both of them send you to pages that say they've been seized by the Federal Government for Anti-Piracy Laws. Do you have new links to get those files or plan on trying to include updated new links?
Does I have to use a game?? :/ I don't have that one who needs :/
the game can be gotten online from most auction sites for about 2 bucks. its an easy game to get. if not, then the 007 and Mechassault games will work as well, but they MUST be the first editions! no reissues will work with the mod
Here is a stupid question, cause I'm sure this is the main reason this is done. However, I have all the legacy of Kain games for the PSone and PS2 but don't have either system anymore. I also still have some other games for different systems, and of course don't have the systems anymore. So, my question is, can you use this mod to run roms like you would an emulator? If so, is there anything special I need to do or any other software I need to download? I have the SNES emulator to play the SNES games I have on my computer, but want to be able to play them on my TV again. Thanx.
yes it is ready to run roms almost out of the box. you would need to locate the emulators for it (google is your friend), and yes it is capable of running PSOne games. i have Atari 2600, NES, SNES, Sega Master System, Nintendo 64, MAME, PC Engine, etc running on mine. and you can even load the Roms off of a dvd if you dont want to take up hard drive space
if this injection process takes any longer im gonna be too drunk to finish the procedure
lol just be patient. it takes a long time over USB 1.1 lol but the copying from the drive to the xbox wont take nearly as long!
About This Instructable
750,656views
157favorites
Bio: techie who believes in making things that i own do what i want or what they were intended to do!
More by daiatlus79:Raspberry Pi/RetroPie Project - Part 1 - Getting Started/Up And Running/Rom copying via  Samba Raspberry Pi/RetroPie Project - Appendix 1 - Installing/Using 1st Gen Xbox/360 Wired USB Controller for use with RetroPie EasyCap DC60 (STK1160) + VLC + Xubuntu 13.10 = OpenSource Video Capture!!
Add instructable to:
