The Easiest Way to Paint Chair Spindles
14,305
29
8
Posted
Introduction: The Easiest Way to Paint Chair Spindles
Don’t you hate how time consuming and tedious painting chair spindles can be? We do too, and that’s why we want to share this one simple trick with you to make the job much easier!
The paint used in this tutorial can be found on our website at www.countrychicpaint.com.
Step 1: Stir and Pour Your Paint
In order to make sure all of the ingredients are well combined, give your jar a good shake and stir it for at least one minute. To make the next step easier and to avoid contaminating your whole jar of paint, we recommend pouring a small of paint onto a paper plate.
Step 2: The First Coat
Since sponges are soft and versatile, they’re much easier to manipulate in small, intricate areas like chair spindles. You’re going to love how quick and easy and quick painting spindles is now!
When painting with a sponge, you’ll notice that it applies the paint in very thin coats. Don’t worry though, that’s a good thing! Painting in thin coats will help you achieve better adhesion for a longer lasting finish. The paint will also dry more quickly so you don’t have to wait as long between coats.
If you’re having difficulty pushing the sponge into any nooks and crannies like the base of your spindles, you can use a small paint brush to touch up afterwards.
Step 3: Add a Second Coat
To get more opaque coverage, you’ll probably want to apply a second coat. Make sure you let each coat dry for about 1-2 hours before applying more paint on top.
Step 4: Distress
If you prefer a more rustic or shabby chic look, try distressing to give your chair a unique finish! You can also leave the paint as is for a more modern finish.
Step 5: Watch This Video!
In this brand new video tutorial company co-founder, Rosanne will show you the easiest way to paint in tricky areas like spindles quickly and efficiently.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    8 Comments
    There is a "dual roller" that you can buy to do this easier, in my opinion.
    https://www.amazon.com/FoamPRO-400-Double-Roller-Frame/dp/B00GM2WRSS/ref=sr_1_2?ie=UTF8&qid=1478126873&sr=8-2&keywords=Double+Paint+Roller
    Thanks for the input! Everyone has different techniques and different preferences of course. We like how the hand held sponges are easy to manipulate in and around corners and tricky areas like spindles.
    Looks great, I have a question Its necessary to sand all the varnish before painting?
    That's a great question! It really depends on the type of finish you're working with and the paint you're using. If the previous varnish is very shiny, it's always a good idea to give it a scuff sanding to remove some of the sheen and give the paint more to adhere to. If you're working with a water-based paint like ours, you'll need to make sure that the previous paint or varnish wasn't oil-based, otherwise priming might be necessary. As we all know oil and water don't mix, and a water-based paint won't be able to adhere to an oily surface.
    I hope these tips help with your next project!
    ~Sarah
