3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Easter Solar Engine
Step 2Stripboard Layout
Stripboard Layout
A very compact embodiment of the Easter engine can be constructed on ordinary stripboard as shown in this illustration.  This is a view from the component side with the copper strip tracks below shown in gray.  The board is only 0.8" by 1.0", and only four of the tracks must be cut as shown by the white circles in the tracks.
The circuit depicted here has one green LED D1 and two diodes D2 and D3 in the trigger string for a turn-on voltage of about 2.5V. The diodes are positioned upright with the cathode end upward, that is, oriented toward the negative bus strip on the right hand edge of the board.  An additional diode can be easily installed in place of the jumper shown from D1 to D2 to bump up the turn-on point.
The turn-off voltage can also be raised as described in the next step.
Of course, other board formats can be used.   The fourth photo below shows an Easter engine built on a small general purpose prototyping board.  It is not as compact and orderly as the stripboard layout, but on the other hand it leaves lots of room for working, and space for adding diodes or multiple storage capacitors.  One could also use just plain perforated phenolic board with the necessary connections wired and soldered below.
6 comments
Jan 3, 2010. 3:41 PMGreenD says:
haha look at that old school led in pic #4.
Ok so, just in general what type of diodes can you use for this?? How do you figure out the voltage required for diodes?? Sorry I'm noob!
Jan 20, 2011. 7:22 PMzer0_da_hero says:
Let me start by saying this is gadget with so many uses it's amazing. I'm also a noob so I have to ask. How can I tell the voltage of a random LED I find in old electronics? What can of test can I do to an LED?
Oct 6, 2010. 1:05 AMwareneutron says:
your brain is holymoly
May 20, 2010. 10:33 AMcaret says:
Hi! what program did you use to draw the board above??? Sorry my bad English  :D
Thanks in advance!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:TinkerJim
Emeritus Professor of Mathematics.
