The Electric Motor
Introduction: The Electric Motor
This is an experiment that will show how a motor works
What you need
A brushed motor
2bearings that will hold the core
Popsicle stick
Hot glue
Soldering iron
Step 1: Take Apart the Motor
Completely disassemble the motor including the magnets and brushes(the electrodes) and make sure that they are operable and in good condition. If not change the motor.
The plates on the electromagnet is an indication of how much power the motor has. The less plates the more power.0
Step 2: Plate
Get a plate or anything to mount your motor on. Clean it of anything that is on there. Then sand it so solder and and glue cAn stick.
Step 3: The Magnets
Cut two 1.5cm parts of the stick. Then glue the magnets on the sticks. Then place the magnets 2.5cm apart on the plate and glue them upright use hot glue for this job
Step 4: The Bearings and Brushes
Use the core to show where to put the brushes. Make a mark with a sharpie. Then solder wires to the brushes. Glue the brush assembly on the mark with hot glue. Then. Put the core in and glue on the bearings. Once glue is firm let go and make sure it can support the weight of the core. Be sure the brushes are touching the receptors on the core.
Step 5: Test
Use a battery to test the motor and and make sure the wires are not shorting out if your plate is metal. Once it works, you are done! Use it to teach kids or even college students!
If you like this instruct able then vote and comment! Thanks foe viewing another lasplaner project!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
    Thanks again! I have entered this but not this exact ones. I have a double upload and one was entered the other wasn't.
    fantastic! you should enter this into a contest!
