3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The "Everyman" Every-Day Carry (EDC) Survival Kit
The \"Everyman\" Every-Day Carry (EDC) Survival Kit
I've seen dozens of Altoid Tin and similar survival kits here on Instructables and elsewhere.  Many of them are quite good, while others--both home built and off-the-shelf--are left lacking some key components.  EDC kits are as varied as the people who create them, but there are some key features and "must have" items they have in common...no matter if you're traversing the urban wilderness or truly miles from civilization.
I just wanted to share the handful of items I carry day-to-day, in the hopes others here would experiment and see what works for them.  The point of an EDC kit is to have something small and light on your person at all times, as a redundancy to the better and more specialized gear you may have for whatever adventure you're planning.  Think of it as the fire extinguisher of your preparedness, in that it should be out of the way and little noticed, but readily available and easy to use should you need it.  While it can be agreed having *something* is much better than having nothing, those "somethings" you carry should be worth their weight and the space they take up.  More importantly, knowing how to *use* those items is much more important than having the best out there.  It's no point to have top of the line gear if you haven't practiced with it, hence the danger of the off-the-shelf "sealed" kits.  Rather than sticking a lighter, stick of gum and a sewing kit into a tin or buying one of those God awful "survival" kits and thinking you're ready to live off the land, these few items are readily available and easy to procure or make.  Remember that survival isn't about comfort, but rather just making it out of there alive.
I should note the best "survival" scenario is to have a game plan and stick to it.  Tell at least two responsible people where you're going, how you plan to get there, when they can expect you back, and at what point they should be alarmed if they haven't heard from you.  Even better, have a description of your vehicle, what you're wearing, and any backup plans you may have should the weather turn.  Have a charged cell phone handy, but realize chances are it won't work when you need it to.  Most survival situations play out within 72 hours, and by far the majority start out as "day hikes".  Pack light and go far, but pack for what *could* happen.  There are many, many articles both on this website and others as to how to plan an outing and pack for it, so I won't repeat those here.
Now on to the "Everyman" (or woman!) EDC kit...
Step 1The Container
The Container
I chose a small stainless steel container for the contents, sealed with a fitted polyethylene lid.  I picked it up at a dollar store, and it was marketed as a stainless steel freezer container.
Why metal instead of a lightweight plastic?
The container can be used to collect and sterilize water, and is even strong enough to use as a digging tool.  Stainless isn't prone to rust and won't impart anything to whatever liquid or food item you prepare in it.  Plus most plastics, especially polystyrene, are prone to differences in temperature and are very likely to get brittle in the cold.  The polyethylene lid on this container is flexible even in the cold, and fitted for a water-tight seal.
15 comments
Dec 29, 2011. 11:28 AMfoughtyp says:
Great ideas here!! You may want to also consider a small tube of superglue. It can seal a cut as well as its normal intended usage.
Nov 30, 2011. 9:24 PMpunkhead58 says:
Great kit!
By the way, are you referring to Doug Ritter the knife designer? He also produces survival kits?
Dec 19, 2011. 9:36 PMpunkhead58 says:
Oh my, he designed the AMK survival kit? I own one, and I had no idea. :P
Dec 16, 2011. 2:17 PMB2BSurvivor says:
Nice instructable. I do find your choice of size a bit bulky for a true EDC. A good EDC is just that, EVERY day carry. Not EVERY day I happen to have on my cargo shorts or pants or jacket with huge pockets. This is why there are so many featuring the convenient size of the Altoids tin. I do agree, too many of these kits are just "how much can you cram into the tin." Someone commented about boiling water being a poorer option for disinfection. Actually, it works better than chemical, especially if you are in a hurry. Do take the time to learn about adjusting for altitude when boiling for disinfection. Also, there are actually medical cases reported in professional journals about people getting ill from overtreated (chemically) water. Diarrhea is nobody's friend, and especially in a survival situation. Too much chem water will take you down that road. 35 years of medical experience teaches many hard lessons.
Also, don't rely too much on the condoms, they break very easily and are hard to carry, store, etc. Over 20 years of military experience on several continents also teaches a few hard lessons.
Dec 16, 2011. 2:52 PMB2BSurvivor says:
Nice that you give credit where due. I agree with your choice on the straws of vaseline VS wax candles. As you mentioned, not much use and often messy in hot climates. Consider putting triple antibiotic ointment in the straws, instead though. It burns much like the vaseline, but can be used for it's antibiotic purpose also. It's all about compactness and weight for an EDC. Consider taking along the individual components that you like from the Swiss card and dump the heavy metal card itself. No need for an extra knife blade, unless you expect your EDC to be all you have for a six month trip. Again, keep it light and compact. This isn't about who's right or wrong. Some of this is personal preference, but all of us can learn from each other. Overall, a good USABLE and USEFUL instructable !!!
Dec 2, 2011. 5:12 PMokoshima says:
not bad, but i dont see any chemical water treatment. water should be the number one priority and relying on boiling it isnt the best idea. plus most water treatments are 1 tablet to 1quart/liter of water.
other than that, a little bulky for my personal taste, and a little overkill on tinder (not that its a bad thing)
if i may make a suggestion though. throw in a couple 1 quart and 1 gallon ziplocs, so many uses with little space. a small candle is also a good addition so you have a small flame, it could make a huge difference if your wood is a little damp. and of course some chlorine based water purification tabs. iodine ones taste foul.
also its nice to see a kit on here that isnt lets see how much junk we can shove in an altoids tin
Dec 5, 2011. 4:34 PMokoshima says:
-facepalms- i missed the iodine.
as for the ziplocks i tend to fold them instead of rolling them, that way they lay flat and the space taken is flatter than rolling them.
a great tinder ive found is similar to your fire straws, instead of petroleum jelly use melted wax onto the cotton then insert into straw, i timed a 1cm piece at 60second burn. so its fairly impressive, needs a small patch fluffed before use though.
ive used candles to help start fires in damp conditions, used the wax from them to create small torches when needed, as dumb as it sounds used the wax as a light duty lube, and a light duty glue. never been a time where ive needed a candle but theres been a few times when its come in handy. just personal opinion really.
if i come off as hating or w/e i honestly dont intend to. its nice to see others are prepared even if its just a day hike or w/e
Nov 30, 2011. 5:25 AMEmcySquare says:
You are right, the idea is very good and shows you used the "ITEM-0" in a survival kit: your brain! ;-)
By the way: There are 2 things I'd like to include (as I have them in my kit)
1) sawing kit : 2 or 3 needles and a couple yard of heavy duty line, black and white
2) zip ties: just like paracord and duct tape you can never have enought of these
Nov 29, 2011. 2:05 AMEmcySquare says:
This kit has some serious thinking behind it. very good
The first aid kit seems very good too
Still I don't get one thing:
Why do all keep addind fishing stuff in theyr kits?
The chances of gettting anyway near to ariver/lake/sea are small, then the chances of having fish in it are even less, those that that type of fish can be fished with those hooks etc are even less... simply too few...
Plus, can you fish? did enyone try? it's not as easy as it seems... so why rely on the "tool" if you don't have the "skill" ??
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Airth
USAF Veteran, tinkerer
