Step 6First Box
1). Take the cable with the plug end on it, and insert it through the "top" cable clamp on one of the boxes prepared earlier, then tighten the clamp evenly.
2). Insert a 2 foot jumper cable through the "bottom" cable clamp on the box, then tighten the clamp evenly.
3). Attach the black and white wires from the cables to a pair of outlets, one cable to each outlet.
4). Attach a green jumper with and the cable's green wire to the first outlet's green screw, then attach the same green jumper to the other outlet in the pair with the other cable's green wire.
5). Install the outlets onto the box cover using the hardware that came with the cover (mine came with screws and nuts).
6). Install the cover onto the box. NOTE: Depending on where and how you plan to mount the box, it might be worth not fully installing the cover at this time.
Add Comment
