Step 9Checkout and Finished project
You need a Digital Multi Meter (you do know how to use one, right?)
Using the OHMS settings, check for shorts between the conductors on the cable. Neutral to ground, neutral to hot, and hot to ground. If you find any, check all your work and repair the problem. Check that the metal boxes are connected ONLY to the ground conductor! YOUR SAFETY DEPENDS ON THIS CHECK!
If the unit passes the short check finish installing the unit where you want it, make sure all the covers are fully tightened down.
Plug the unit into power. If you pop the breaker you plugged into, check your work for shorts again.
Use an outlet tester to check all the outlets, including the cable receptacle. If the outlet tester shows correct wiring in all the outlets, you can use the project. If not, find the error and repair it before use.
comment
Add Comment
Add Comment
