The Eye Within the Eye
860
27
4
Published
Introduction: The Eye Within the Eye
I have always been fascinated with string art. When I saw this contest,I decided it was time to do my first instructable.
Step 1: Materials Needed
  • paper
  • pencil
  • ruler
  • Black thick chart ( i used fabriano sheet)
  • thread (i used embroidery thread) - white, multicolored pinks)
  • needle
  • pin or thumb tack
  • scissors
  • Paper clips
Step 2: Design Your Pattern
  • I drew out the pattern on a plain drawing sheet
  • My largest square is 28cm x 28 cm
  • The squares inside are drawn by connecting the midpoints
  • Mark the lines in gaps of 1/2 cm
  • Draw and check the pattern you prefer to use
Step 3: Transfer the Pattern Points to Main Sheet
  • Please ignore the pencil pattern because while I was doing it , I changed it .
  • Use a pin or thumb tack to mark the points
Step 4: Sheet With the Points Transfered
Step 5: Start Your String Art
  • You need to start with the smallest square
  • The second, third and fourth squares follow the same pattern
Step 6: Square 5
  • Join the points 1 with 1, 2 with 2, 3 with 3 etc
  • Do this for the bottom side also
Step 7: Square 6
  • Mark 9 points from each corner and join according to the pattern
  • After finishing the square , realized that it needed something more...... so added square 5 pattern to top and bottom parts
Step 8: Square 7
  • You need to follow the same pattern for the top and bottom sides
  • While I was doing it , I realized the strings were too long so they were becoming loose. So I decided to to weave it as I continued
Step 9: The Corners
  • I used white thread for the corners
  • Follow the pattern and join the like numbers
Step 10: Final Output
  • Used a whitener to put a dot in the center of the eye
I hope this instructable was easy to follow.
    • BBQ Showdown Challenge
    • Backpack Challenge
      Backpack Challenge
    • Stick It! Contest
      Stick It! Contest
    4 Discussions
    Cool string art :)
    did you do that
