The original design, as shown here, featured a pair of glasses as the basis for the eyewriter design:
Since that first video, we've been hacking on and developing the project, and we have a new design, which we've called "eyewriter 2.0" which improves the accuracy of the device, and allow for people who's heads are moving slightly to also use an eye tracker. The original eyewriter, designed for a paralyzed Graffiti artist TEMPT1, is designed to be worn on a completely motionless head. The 2.0 design, which uses a camera and LED system mounted away from the head, can be used by people whose heads are moving slightly, such as MS patients, and people who wear glasses, etc.
This eyewriter system is cheap, and completely open source. At the moment, it costs about 200$ in parts. Traditional commercial eye trackers costs between $9000-$20,000, so this is a magnitude of order cheaper, and is designed to help anyone who wants or needs an eyetracker.
This fall, we've been showing off and demoing the 2.0 device -- check out the eyewriter 2.0 in action -- we even hooked it up to a robotic arm, to draw the artwork people make with their eyes:
http://www.switched.com/2010/12/13/eyewriter-teams-up-with-robotagger-to-print-kids-ocular-artwork/print/
(The 2.0 device was designed with help and input from Takayuki Ito, Kyle McDonald, Golan Levin and students of the eyewriter collab at Parsons MFADT. Thanks also to the Studio for Creative Inquiry / CMU for hosting a session for development)
Remove these ads by
Signing UpStep 1Overview
From a technical perspective, the 2.0 system works by strobing 3 IR illuminators every frame. On even frames, it uses the center illuminator (located around the camera lens) and on odd frames it uses the 2 side illuminators. On even frames, the pupil appears bright, since the IR light is actually bouncing off the back of your eye, like red eye effect. On odd frames, your pupil appears dark. The difference between the two allows us to isolate and track the pupil in realtime. Additionally, the glints (reflections of the IR illuminators) of the dark frame are tracked, and these, plus the info on the pupil, is calibrated to screen position using a least squares fitting process for an equation that provides a mapping of glint/pupil position to screen position.
| « Previous Step | View All Steps | Next Step » |
http://www.openframeworks.cc/download/older.html
One Question: We use a LOREX IR Baby Monitor to keep tabs on her when we are not in the room with her. We have a spare camera unit, which has the IR LED's already integrated. I'm not sure if it strobes the IR's, or how to find the vSync pin. Can anyone recommend someplace I can find this information, or if anyone has had success using this type of camera before?
Thanks,
CK
I work at a science museum and we are trying to get this working. The guys in the shop have done their part with all the hardware, and now it's up to me, for the software side. I've gotten the software running on both Windows 7 and Mac OS X, and it does recognize my eye-- however, I can't seem to get to the different modes (calibration, drawing, pong, etc) from the app. If I change the mode in the code and re-compile, I can see those different screens. But it sounds like I should be able to press the spacebar from within the main app, and find the calibration screen. Seems like this is crucial to get to interact with it as a mouse!
I'd really appreciate any pointers or suggestions you might have.
http://cid-f966c677a7c86219.office.live.com/embedicon.aspx/Remote%20Eye%20Tracker%20Windows
Refer to the instructables to change from demo mode to live. No documentation on the settings so you are on your own. Took me a long time to find the sweet spot to get the glints to lock on, but I overlook a lot of obvious things. Couldn't get the typing program to speak the words but I'm thrilled I got it to work at all.
Real
Uploaded the cbp file and others in the directory, then zipped everything except the bin directory which is already zipped and uploaded. Lemme know if thats what you needed.
Thanks!
OF_ERROR: Error allocating a video device.
OF_ERROR: Please check your camera with AMCAP or other software
AMCAP and the CL Eye Test both show that the camera works correctly. Not sure what to do next. Tried values 0,1,2,3,4 under DeviceId in the settings file but it still shows "SETUP: Setting up device 0"
I had a little luck emailing the people who wrote the code directly when I got stuck compiling but the question had to be very specific to get a usable answer. Most responses were "I don't know what you are doing wrong" and "Keep trying until you figure it out".
Thanks!
Thank you!!
https://skydrive.live.com/?cid=f966c677a7c86219&sc=documents&id=F966C677A7C86219%21103
I recently started to build an eyetracker and tried the eyewriter.
First question:
I use the linked eyewriter project, but it looks as the first eyewriter-version and calibration does not work... The software UI looks much simpler. (I got the eyewriter code working with the current open frameworks version...)
Second question:
Do I really have to do the strobing stuff? I want to build an head mounted device, using right now just one IR-Led... does the software work with a head mounted device, using only one, not strobing ir-led?
I am not a programmer. Trying to compile the project to run in Win XP via Code::Blocks and after shuffling missing files into place, I'm now at line 52 of trakingmanager_controlpanel.cpp with error message ofxLibdcPtGrey was not declared in this scope & cam was not declared in this scope. Where should I go for help?
Better yet (as russ_hensel posted), is there a windows executable of the eyewriter software available anywhere?
Thank you for posting the project!
Real
I had a similar problem and contacted the developers directly. Kyle McDonald, one of the core programmers replied with this:
"to build ew 2.0 in windows, i recommend using this branch:
https://github.com/eyewriter/eyewriter/tree/remoteEyetracker/eyeWriterTracker
and using 0061. it might work with 0062 but i'm pretty sure that last
time we updated it we were still using 0061.
the 'osx specific' calls you see are probably calls to libdc1394,
which is what ofxLibdc is wrapping. ofxLibdc only compiles on osx. the
.cbp shouldn't include ofxLibdc, and there are switches in the source
code like this (in inputManager.h):
#ifdef TARGET_OSX
#include "fireflyVideoGrabber.h"
#endif
so that ofxLibdc is only included when you're on OSX.
if you have a specific error while building, let me know.
-kyle"
Hope this helps. Meanwhile, to switch branches and things like that, read up on how to use git and github etc.
- trying to get to point where I can ask a coherent question...
Thanks Again!
Real
First off, have people gotten this working on windows (w7, in particular) easily? Or is there a bunch of fumbling with the code to get it going? Are there any instructions available? Do I just download the files at this link? https://github.com/eyewriter/eyewriter/tree/remoteEyetracker/eyeWriterTracker
Second, can this device replace a mouse as a general input method for the computer? Will it work with any program? Or do I have to be in the eye writer application for it to work? I'm much less interested in drawing than I am with using a mouse to control anything I want on the computer, like a conventional mouse. I don't need it to click, just to move the cursor.
Third, how accurate is this? Are people able to control the cursor to within +/- a few pixels? More? Less? How much can you move your head? A few mm? A few inches? A few feet?
Thanks in advance if anyone can answer these questions!
In the UK its really hard to find some of these components, Ive ended up getting most of them shipped over from US at great cost.
Heres a UK supplier for board lenses. Could you let me know if this would be suitable please?
http://www.onlinesecurityproducts.co.uk/genie-cctv-lenses/genie-cctv-gl25-pcb-minature-dome-lens-25mm.html
I am also UK based and am thinking of building an eyewriter.
What mount did you use with the lens?
Thanks
Im sure this wasn't strictly necessary, but Im a software guy primarily, and If my eyewriter wasn't working, I didn't want the uncertainty of thinking Id ordered parts which weren't quite right.
I struggled to find any UK suppliers for most of the parts. The rheostats and a few other bits Ive since found on ebay though, so give that a try.
I intentionally ordered too many lens mounts (just incase), but I doubt I'll ever use them. If you just need one, drop me your address and Ill be happy to send you it.
