3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The EyeWriter 2.0
Step 3Software - openFrameworks & EyeWriter
The Eyewriter 2.0 requires a few pieces of software for building and running. In this step we will explain how to download and install an IDE, openFrameworks, and the eyeWriter software.
A. Integrated Development Environment (IDE)
  • An integrated development environment (IDE) is a software application that provides comprehensive facilities to computer programmers for software development.
B. openFrameworks
  • Openframeworks is a c++ library designed to assist the creative process by providing a simple and intuitive framework for experimentation.
C. EyeWriter GitHub
  • GitHub is a web-based hosting service for projects that use the Git revision control system. It is a platform that allows people to exchange and share code.
  • Click Download Source on the top right menu.
  • Choose ZIP format.
  • After download is complete, unzip the file and place the "eyewriter-xxxxxxx" folder into openFrameworks "apps" folder.
  • Open the "apps/eyewriter-xxxxxxx/eyeWriterTracker/RemoteEyeTracker.xcodeproj" file to test that all installations are working correctly. The source code should load in your IDE software.
  • please be sure you're compiling for your current Operating System (the eyewriter software was originally compiled for OSX 10.5 so you might need to change compiling from 'base SDK' to 'OSX 10.6')
  • Build and Run the source code. The Tracking screen should load in video demo mode.
« Previous Step   View All StepsNext Step »
3 comments
Nov 26, 2011. 7:24 AMtmandragora says:
I can't compile the project with xcode and the newest openframeworks download. Lots of errors, warnings that some stuff is deprecated. Do I need an older openframeworks version?
Apr 26, 2012. 12:18 PMRealMaxwell says:
I used OpenFrameworks pre release v0.061 - you can download it here:
http://www.openframeworks.cc/download/older.html
May 27, 2011. 10:16 AMd_dooms says:
I'm not able to open RemoteEyeTracker.xcodeproj with Visual C++ IDE, could you walk me through?
Thank you!!
Jun 20, 2011. 7:55 PMatl1 says:
I was going to ask the same thing, I did some research and someone was nice enough to compile it for windows. Here give this link a try:
https://skydrive.live.com/?cid=f966c677a7c86219&sc=documents&id=F966C677A7C86219%21103
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:thesystemis
