Introduction: The Fan Double Secret Compartment
This is my first Instructable, And is it a fan secret compartment.
Step 1: What You Will Need
A Styrofoam Box, A Screwdriver, A Knife, A Fan!!
Step 2:
Unscrew the height adjuster all the way, And pull out.
Step 3: Follow the Photos
Step 4: Get the Foam Box
The first photo will show you what you will have
STEP:4.5 cut a rough hole in the box
Step 5: Push the Foam In
Push the foam in
Step 6: The Second Secret Compartment
The steel pole on the base of the fan motor and blade unscrew (there is a little nut when you unscrew this so be careful not to lose it)
And pull out the pole
Step 7: Inserting the Stoppers the Foam
Using the pole cut out foam circles (I recommend two)
When you put it back together take note on one end of the poll will be a few dints they go up
Step 8: Reassemble the Fan With the Goods
Make sure you put the black stopper in big end on the foam small end up, When putting this part together assemble it up-side-down so the goods don't fall out!
Secret Doors and Compartments Contest
