The Fastest Way to Tie a Tie - How to Tie a Tie in less than 10 Seconds
 by tycoyoken
This is known as the fastest way to tie a tie. Get it done in 10 seconds. Just in the case you are going to be late to your work, you can use this way to tie your tie. I show you how.
This tie tricks is full windsor, but you can adjust it into half-windsor knot as you want.
This instruction come with video, so you can repeat watching it as many time as you want.
First Step: turn it over and put the tie like this position
Step 1: Hand tricks
Twist you hand and insert you hand into the hole, then hold it with you thumb
Step 2: Turn it over
turn it over and insert you hand into the other hole
Step 3: Hold it with your thumb
hold it with your thumb and insert the tail in the hole here
Step 4: Hold the tail with your right thumb
hold the tail with your right thumb,
Step 5: Adjust it
Adjust the position carefully
Step 6: That's all
This all
Step 7: See
here is the completed tie, is that beautiful. this instruction come with video
Detoxiodine says: May 11, 2013. 12:09 PM
That's great for a Windsor. But if you want to have your tie tied in a more elaborate way - like the Eldredge or the Trinity knot -, you actually have to learn how to tie it.
mensties says: Jul 14, 2010. 2:47 AM
nice i like all your work..great job http://www.ties-necktie.com
oliviaj says: Oct 7, 2008. 2:48 AM
By far the easiest way I've seen so far. First try! As a Step Mother that has to tie her Son's tie for every Debate Tournament, (Gotta' teach Him this method) I usually have to give it couple of tries with other methods to get the full windsor. Thanks for sharing!
AznPanda says: Jul 10, 2008. 6:08 PM
Ok this is cool... but uhhh how would you do it like that on ur newk -.-
kimro in reply to AznPandaSep 9, 2008. 6:58 PM
send the small end around your neck before you put the it trough hole after the twist
kimro says: Sep 9, 2008. 6:52 PM
this work well for me it's more of a bar trick thou. after about 3 trys i can get a good knot in less then 10 sec more like 5
dizzytaylor says: Mar 13, 2008. 5:29 PM
Most excellent and amazing! I can't even do a Windsor knot the old fashioned way.
2tieatie says: Jan 13, 2008. 7:55 PM
the site is www.2tieatie.com
2tieatie says: Jan 13, 2008. 7:54 PM
This is OK, but not really clear to me. Not sure what knot this even is. Here is a resource that has over 15 different step by step diagrams of how to tie a tie . This has tie video instructionstie video and covers all the way from the Bathus knotto the Windsor knot. It really is worth referencing also. Hope this helps.
qdogg says: Dec 5, 2007. 11:51 AM
I can tie a tie in one second. I use a trick taught by a magician known as the Amazing Randi and appeared in the now defunct OMNI magazine of the late '70's. It's way cool & you only need one hand! I often flip the tie over my shoulder as I'm tying it so others can't see the knot. Then I ask them to count while I "tie" the tie. I whip it out in an instant, already tied. I'm sure you can find this method somewhere on the web. I don't have time right now to make a video of it or describe the method... maybe later.
gbosbiker says: Dec 4, 2007. 5:19 PM
defiantly takes more than 10 seconds. you have to make all the pre-fold twists then do that procedure. then put over your neck. probably takes 20 seconds. I can do the normal full windsor on my neck in ten seconds so it is much easier.
QuickTie says: Dec 4, 2007. 9:32 AM
hmmmmm I can tie a full windsor in about 8 seconds...and its round my neck..lets have one for a dickie bow
cpt_hammer says: Dec 3, 2007. 6:34 AM
is this a full windsor or a half-windsor knot when finished?
tycoyoken (author) in reply to cpt_hammerDec 3, 2007. 7:51 AM
myckle in reply to tycoyokenDec 4, 2007. 5:09 AM
Could you put up a direction or another video for half-windsor option? This trick looks awesome and it'd save tons of time if there was a half-windsor option. Personally, I've never seen that many people with full windsor ties. Guess people are too busy to spend time on that extra loop. :P Thanks much.
bytehead says: Dec 3, 2007. 6:32 PM
Interesting. But I can still tie a tie on myself without looking, and while it might take longer than shown, it's not much longer. And it's already on my neck. 20 inch neck's suck BTW. :-P
GorillazMiko says: Dec 3, 2007. 4:57 PM
nice!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
