The Fishtank Blender. "The Blender Tank" by shaggs31
Contest WinnerFeatured
Step 5: Make the hose water tight.
I encountered a problem with making the hose connection not leak water.  Hear is a very simple way to solve this.
To make the connection water tight, take the bubble rock and connect it to the end of the hose inside the tank.  Then feed the hose back into the hole.  Once you feed the hose enough so the end of the bubble rock starts to enter the hole that you made, it will create a seal.  Push it down so it makes a tight seal.  No glue is needed so that there is no chance to contaminate the water.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
