This is the "Flying Frogs," a minor ride in the Froggy World amusement park for adventurous plastic frogs.
This started as a sketch, then the tower and cross bar holder were designed and 3d printed:
http://www.thingiverse.com/thing:53059
The frogs were made out of clay, baked, then glued to the cross rod.
Step 1:
Start with a base and a couple of extender pieces.
Use acetone (nail polish remover--available in most grocery and drug stores) to "weld" the pieces together.  I "paint" the pieces with a small brush then put them together.
Edgar says: Feb 25, 2013. 2:32 PM
Brings back fun childhood memories... :) Voted!
Gone to my Blog.
http://faz-voce-mesmo.blogspot.pt/2013/02/fablab-ras-e-reprap-magazine.html
MikeTheMaker (author) in reply to EdgarFeb 25, 2013. 4:02 PM
Thank you . . . and thanks for posting on your blog!
Edgar in reply to MikeTheMakerFeb 25, 2013. 11:31 PM
You're welcome, keep it up! :)
nwlaurie says: Feb 24, 2013. 12:32 PM
Love your layout!
MikeTheMaker (author) in reply to nwlaurieFeb 24, 2013. 6:09 PM
Thanks--I'm working on train controls now.
gregoryfenton says: Feb 24, 2013. 7:13 AM
I love this :)
Have you thought about using pneumatics to make the ride go up and down?
MikeTheMaker (author) in reply to gregoryfentonFeb 24, 2013. 8:26 AM
That's a good idea! Maybe I can modify an old pump or something similar . . .
gregoryfenton in reply to MikeTheMakerFeb 24, 2013. 9:41 AM
Thinking about it some more, you wouldn't even need the pneumatics.
Just a piece of pipe shaped like a tiara ===|\ so the arm can go up and down it. Hope these images help describe what I mean.
Yellow is the new part required.
You would need to modify the part that attaches to the motor (let's call this part Fred) by making it slightly less wide than the distance from the motor spindle to the edge of the motor so it can rotate freely inside the pipe.
You would also need to mount the crossbeam using a pivot and cutting a channel inside Fred so the crossbeam can move up and down on the pivot.
Still with me?
Here are my 5 minutes in gimp images that hopefully show what I mean
MikeTheMaker (author) in reply to gregoryfentonFeb 24, 2013. 2:54 PM
I see what you're saying . . . that would work :)
azharz says: Feb 23, 2013. 9:47 AM
Very Nice
Very Nice
J-Five says: Feb 22, 2013. 4:46 PM
Cool,
By the what's the speed?
And what would happen if like went 20 times the speed?
MikeTheMaker (author) in reply to J-FiveFeb 22, 2013. 4:57 PM
It's 3 revolutions per minute.
Since it's unbalanced (the red and blue frogs are larger), something would quickly come undone at 20 times the speed.
Stay tuned--I may sling some around in swings at a much higher speed :)
J-Five in reply to MikeTheMakerFeb 23, 2013. 7:39 AM
Makes sense.
randofo says: Feb 22, 2013. 10:04 AM
I really like this series of projects.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
