3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Four-Year Plan: a Long-Wheelbase Recumbent Bicycle
  • last photo ←
I built this recumbent partly as a test-platform for some ideas I had about recumbent design and partly just to see if I could during my senior year of college.  Since my school is in the mountains, I wanted the bike to have somewhat higher ground-clearance than some other recumbent bikes that I've seen.  I also built it with fat tires in mind, since some of the fastest routes across campus aren't paved the whole way.
The frame is MIG welded together from a pair of donor bikes and a length of 1 1/2" 14-gauge square steel tubing, which was overkill, but it was the best that I could get from the local metal supplier.  In its current configuration, I'm running it as a 3x7 using salvaged Shimano Acera components and a seven-speed megadrive freewheel which gives me 24x34 in my lowest gear, giving me the range to tackle anything that the Appalachians can throw at me.
The seat is still a work-in-progress, and what you see in the pictures is a temporary solution until I have the time and resources to build a new one.
8 comments
Mar 31, 2012. 10:32 AMtherishel says:
Have you seen www.recycledrecumbent.com? The author of that site has a lot of free information on building your own long-wheel base recumbent including patterns, lots of pictures, materials, etc. I built a recumbent using his plans including a mesh seat that has proven very comfortable and durable. Check it out.
Feb 27, 2012. 2:05 AM-insert dreams- says:
Hey;
I am currently building my own recumbent bike from an old tandem and I wanted some pointers on how you set up the gears, some details about the seat, and also about setting up the steering. I appreciated your tip on chain length and I know each bike is different but if you had some other pointers or advice...
I was thinking that mounting the seat on a crane type thing would be great so I could change the seat distance, but I'm kinda scared of the complexity involved.
For the seetring under the seat, is that better than having them in front ? since its under don't you have a smaller turning radius?
A recumbent is great once you are rolling but needs more work for initial speed, I think. how did you set up the gears?
thanks a bunch
Sep 26, 2011. 7:46 AMcheeyah says:
Have you had any problems with chain tension due to the long chain? Some bikes I have seen have a couple of guides or jockey wheels to try to keep the chain more supported. Seems like they could be useful but your design would be far simpler if it works alright. Nice job with the bike.
Aug 19, 2011. 6:12 AMcjbikenut says:
This looks nicely done! Enjoy it.
Aug 17, 2011. 8:45 AMmikeasaurus says:
your bike looks great, have any pictures during the build?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:TheMadTinker(The Real Me)
I'm a top-hatted, kilted, bike mechanic and author with a fondness for silly things and delicious food. Holler at my Philly folks!
