The Fox Hole, a Hooded Winter Baby Sling
 by jmefox
FeaturedContest Winner
The Fox Hole is a baby sling that can be used for babies 2 months and up, in three positions. The front carry, hip carry, and back carry. The Fox Hole sling has a removable hood and faux fur or shearling liner to keep baby extra warm.
Step 1: Materials
Heavy Weight Cotton Fabric and Faux Fur or Shearling Lining 1 yd. of 60” fabric for each.
Separating Zipper 12”, Thread
Step 2: Measuring for Fit
This is a winter baby sling and intended to be worn over a coat or layered clothing. For this reason you will want to measure while wearing a coat. Measure from shoulder to hip. For the Fox Hole sling you will need to add 3" to this measurement.
Step 3: Cutting the Fabric
Cut fabric on the fold 23" x your shoulder to hip measurement plus 3" (my shoulder to hip measurement is 24” in my coat, our cut was on the fold 23" x 27”).
Fold fabric again lengthwise so all four open corners are together forming a long rectangle. Measure and mark 3 inches in from the four open corners. Begin cutting at the edge of the fold forming a curve that ends at the 3” mark.
Repeat for lining.
Use Pattern pieces to cut hood. (to print, the lining will need legal sized paper)
Step 4: Sewing Bottom Rail and Curved Seam
Unfold fabric and lining. Pin right sides together along one long edge (this will be the bottom rail of your sling) sew along this edge using a 1/2” seam. Press seam open. Fold right side together matching curved edges; fabric to fabric, lining to lining. Sew along curved edges.
Step 5: Sewing Top Rail and Zipper
Turn sling with wrong sides facing and gently press all seams. Press under a 5/8” hem on the top rail of both fabrics, pin lining to fabric. Insert one side of zipper (the side without the pull) centering the zipper at the curved seam. The zipper will be sewn in between the lining and fabric. Top stitch the top rail together securing zipper in place (using zipper foot). Top stitch lower rail and curved seam if desired.
Step 6: Sewing the Hood
With right sides together stitch back curve of fabric. Repeat with lining. Clip curve on fabric.
Matching center seam with right sides together and fabric inside the lining, sew along the front edge. Turn right sides out and gently press seams. The lining will roll to outside forming a furry trim.
Step 7: Sewing the Hood Zipper
Press under 1/2” seam on bottom of hood. For both fabric and lining.
Pin zipper centering with back seam. Top stitch along the bottom of hood securing the zipper in place (using zipper foot).
Step 8: Optional Embellishments: Hood Puff
Cut out a 5.5” circle of lining (or cut to your taste). Gather stitch around circle, pull stitch in to form a ball, stuff with poly-fil. Stitch onto hood.
Step 9: Saftey Rules
Certain Slings have gained media coverage due to injury, please follow these safety rules for carrying your baby
  1. The baby should be close enough to kiss.
  2. The baby should never have his/her chin resting on his/her chest.
  3. The baby’s head should always be above the rest of his/her body.
  4. The baby’s knees should always be higher than his/her butt.
  5. The baby’s face should not be covered by fabric.
  6. The baby’s head should be supported.
http://babywearinginternational.org/
jojoguy10 says: Oct 22, 2011. 8:52 PM
I'm stuck on this step. You said to "pin lining to fabric" but I'm not sure where you're talking about. Also, I'm a bit confused on where the zipper is going. Is there any way you can make this more clear for me? Thanks so much!!! It's really adorable and hope I can figure it out!!
morriganfaye in reply to jojoguy10Dec 20, 2011. 11:01 AM
lining is the third fabric type that is used in the middle to make it more stable. its usually a cotton fabric of sorts. it will go in between the front and backside of the garment its never visible. You should pin it to the wrong side of the fabric ( best that you do it on the green fabric it will be a lot less of a pain to sew) you can google how to place lining and it may give you a better idea
glyra says: Jun 14, 2011. 7:37 PM
Amei, muito lindo.... Bem quentinho.
Parabéns!
jessandstavro says: Nov 30, 2010. 10:01 PM
A sling with a hood! Beyond clever! All my years of babywearing never saw this...go you!
slisle says: Apr 17, 2010. 5:29 AM
This is adorable and so is your baby!
porcupinemamma says: Apr 3, 2010. 5:46 AM
Subscribed, voted OUTSTANDING.  Very thorough steps.  Hope you continue to post :0)
thejimster says: Mar 11, 2010. 10:24 AM
Lol what a great idea!
By the way, I think the baby is really really cute!
twiztedreams says: Mar 11, 2010. 6:43 AM
 Oh my goodness! This is so adorable! Way to go! I voted
dckirk says: Mar 9, 2010. 1:54 PM
 Super super cute!  Almost makes me wish I still had a baby young enough to carry around...
sarahfish says: Mar 8, 2010. 8:24 AM
 freaking adorable! so, we are to line up the center of the hood with the curved seam of the sling, or should it be offset some how?
jmefox (author) in reply to sarahfishMar 8, 2010. 9:07 AM
Yes the Hood will be centered on the seam. We used a zipper so the hood would be removable if you wished. In step 5 are the directions for centering the zipper.
Utahtabby says: Mar 7, 2010. 3:36 PM
How do we cut the hood pattern? I don't know what size or shape to cut it.
jmefox (author) in reply to UtahtabbyMar 7, 2010. 5:07 PM
So sorry it looks like the hood pattern attachment did not add I will add this info tomorrow
jmefox (author) in reply to jmefoxMar 8, 2010. 9:04 AM
The pattern pieces have been added to the cutting step!
domestic_engineer says: Mar 7, 2010. 2:26 PM
That is REALLY REALLY REALLY Cute!
Thendongofti says: Mar 7, 2010. 2:21 PM
This is gorgeous!!! I'm SO annoyed I didn't see it earlier, as it's just heading into spring and I'm on my last  (4th) baby :-( I'd love to make one of these for him as it looks so cosy and he's always carried, but by the time winter comes around again he'll probably be to heavy for me!!
Oh well- it's a lovely idea and I wish I'd thought of it!!
x
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
