The Funnel Catapult
Published
Introduction: The Funnel Catapult
     I was reading in my favorite book, "The Mischeif Maker's Manual" and I found this. It originally called for a huge funnel and 1/4" rubber tubing. So I downsized it and came up with this one.
     This thing is great for shooting marbles, Altoids, coins, Barbie doll heads, etc. If it fits in the funnel should work fine, just don't shoot anything that is on fire or explodes. I apologize to my fellow pyros, but safety first.
     I AM NOT RESONSIBLE FOR ANYONE OR ANYTHING YOU MAY BREAK, INJURE OR DESTROY.
This is my first instructable by the way, so constructive criticism is welcome!
Step 1: Tools and Materials
You will need the following:
Materials
  • One tiny funnel ( I went to Walmart and picked up a 5-pack )
  • Two library rubber bands ( The really long ones)
Tools
  •  A knife or scissors
  • A drill ( optional)
Step 2: Preparing the Funnel
Now that you have all of the parts, it's time to prepare the funnel for the rubber bands.
In order to do this, you have to make 4 holes in the funnel.
     To do that, take your knife (or drill) and place the tip about 1cm from the top and turn your knife while pressing down. Once you finish that hole, make another one 1cm below it.
     Now turn the funnel 180 degrees and do the same thing.
NOTE: Your knife doesnt have to have a tip like mine, the top one of the second picture will also work.
Step 3: Attaching the Rubber Bands
Now all we need to do is attach the rubber bands.
     First, cut the rubber bands so they are no longer circular. Next, thread one end through the first hole you made and pull it halfway through. Then thread the end inside the funnel through the second hole. Using the other rubber band, do the same on the other side. When you are done, you should have 4 strands sticking out of the funnel.
Step 4: Setup and Fire It!
Now that you are done with building it, it's time to know how to use it.
     You will need something like a school desk, or a table, chair, or something like that. All you have to do is tie one side to one leg, and use a differrent leg for the other side.
     Firing is easy, all you need to do is load it, pull back and let go.
Once again: I AM NOT RESPONSIBLE FOR ANYTHING YOU BREAK, INJURE, DAMAGE, OR DESTROY
NOTE: the last picture is of a larger one I made.
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    4 Comments
    You should make the funnel using a PAPER coffee cup and enter it in the "Paper Cup Challenge" here on instructables. You can win some nice prizes!
    Wow I would have never thought of that. I think I will do that and I will DEFINITELY give credit to you. Thanks so much
    Hurry up, I think the contest closes May 9th.
