3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The GameBoy DS - Play any Nintendo handheld game
My project works on this equation, Nintendo DS + GameBoy Color + GameBoy Advanced SP parts = GameBoy DS
When the Nintendo DS first came out, I was pretty excited. I was especially happy to hear about the GameBoy Advance slot. When I got my DS, I was sad to find out that the Advance slot could not play original GameBoy games.
After a few years, I decided that it would be really cool to put my DS inside an original GameBoy shell. After a little bit of time working on that project, I remembered my wishes that the DS would play old GameBoy games. In order for my GameBoy DS to play any Nintendo handheld game ever made, I decided that a GameBoy Color would be the best option. It was also a lot smaller to save space.
My original idea with only the DS inside would have turned out to be only a little larger than a normal GameBoy. However, after adding the GameBoy Color it is almost the size of two GameBoys stacked up.
This turned out to be a little harder than I expected, but I have pretty much pulled it off at this point.
The total cost of this project was roughly $130-$150. It was probably about two months of work overall. I normally only had an hour or two a day, so it would have gone faster if I did not have to worry about work and all that.
Here are the needed supplies for this project:
- Original GameBoy
- GameBoy Color
- GameBoy Advance SP
- Soldering Iron
- Hot Glue Gun
- Basic Electronics Knowledge
- Patience
- A Steady Hand
Step 1Start by getting your outer case ready
In the beginning of the project, I only wanted my Nintendo DS inside the shell of an old GameBoy.  What I did in the beginning was take apart my GameBoy and save the outer case to use for my project.  The internal parts of the GameBoy I used still worked, so I saved them to try and repair my old GameBoy that no longer worked.  Once I had the outer shell, I marked the places where I would need to grind away with my Dremel to make the DS connectors still be exposed.
I took apart most of my DS and ground the edges down to make it fit inside the GameBoy better.  This helped me mark the spots of the old GameBoy more accurately.
Luckily the DS is roughly the same size of an original GameBoy.  Also a few of the existing holes in the case lined up with a couple connectors on the DS.  Another great thing is that the battery compartment for the GameBoy just happened to be in a location that lined up with the battery of the DS.
It was after grinding my GameBoy case up that I decided to add in a GameBoy Color.  So I knew I had to fill in some gaps when I had finished this up.  I detail the GameBoy Color portions in the next few steps.
28 comments
Oct 24, 2011. 11:20 AMashannon1 says:
excuse me, not trying to be rude, but wouldn't it just be easier to buy a gameboy advanced, and a 3/DS and play original/color/advanced gameboy games on the GBA, and the DS games on the 3DS?
Apr 24, 2012. 6:43 PMmechaninja says:
Yes! Pure genius! More gaming menageries from the man! Just off topic, but what did you do with the Gameboy "guts"?
Apr 30, 2012. 6:49 PMmusick_08 says:
Do I feel a case mod coming?
Apr 30, 2012. 9:08 PMmusick_08 says:
Hmm, what if you vacuum formed and created your own case for it? There are also a lot of hacks for them. The possibilities are endless
Mar 21, 2012. 4:08 PMtinmankingkinney says:
Could have tried wiring a third screen and all the needed buttons off the ds board for the game boy games. might have slimmed it down a bit.
Mar 21, 2012. 4:11 PMtinmankingkinney says:
*never mind, re-read the beginning, I thought it was supposed to be mainly a case mod, not a case+hardware mod.
Sep 19, 2011. 3:27 PMachris4321 says:
You did great on this but wouldnt it be great with the bemo mod because of space?
Sep 11, 2011. 9:27 AMsuperduperdrew says:
just wondering,could you remove the DS gameboy cartridge slot and put one from a gameboy advance in? If so,you could play gameboy color and originals like that. Because the DS gmaeboy slot has plastic tabs on the sides and block them.
Jun 16, 2011. 8:31 PMmheaton1 says:
Haha. Now you should try putting in a 3DS!
Jun 1, 2011. 12:57 PMpokekris99 says:
I might mix this idea with the DIY Beemo idea.
Beemo Video Game:http://www.instructables.com/id/Adventure-Times-BMO-Roommate-GBC-Mod/#step1
May 15, 2011. 9:02 AMmheaton1 says:
Wheres the second screen for the DS?
May 15, 2011. 2:19 PMmheaton1 says:
Ohhh okay I see how it works :D
Apr 10, 2011. 1:42 PMDrigax says:
Hmm...ever consider using a GameBoy advance or GameBoy micro instead of the more bulky GameBoy color?
You wouldn't have had to worry about the real estate as much, and the only major issues would be wiring a cartridge slot to the exterior of the GameBoy shell.
Apr 10, 2011. 7:41 AMpandadude says:
I gotta agree with you, when I got my DS a few years back I was so annoyed that I couldn't play Gameboy color games.
Apr 10, 2011. 4:30 AMmwwdesign says:
Great! Maybe use a flat strip of metal and curve it, instead of using cardboard, then 'fill' over it with plastic strips?
Apr 4, 2011. 6:50 PMzack247 says:
well i cant say that you chose form over function, but it still gets my vote for creativity!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:skittlespider
I consider myself an average guy. I have a BFA in graphic design. I like tv, movies, music, video games, and anime. I do some video editing and animation as a hobby, but not too much lately. Stay tune...
more »
