3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Genuine NES Bartop Arcade
Like everyone else in the world, I grew up with a love for video games.  Specifically games for the Nintendo Entertainment System.  I don't know why, but I can't really get into playing all the modern games.  The nice thing about newer consoles is that they are easy to keep out of sight (wireless controllers).  Unfortunately to get your daily fix of NES, you need to dig through the closet, find the "good" controller, all the wires, etc etc and half an hour later you are playing.  My goal was to prevent this from happening.  And no, emulators just won't cut it.
I've always enjoyed the feel of playing with an arcade controller.  Sure the NES Advantage is OK, but it doesn't give you that authentic feel a real arcade machine does.  To solve that, I was inspired by a friend to build a NES Bartop Arcade machine.  I could have gone the easy route and built a MAME console, but I find emulation just isn't the same.  And thanks to Brian from http://www.retrousb.com I can have all my games at my fingertips with the PowerPak.
I could have made things easier by using a NOAC (NES On A Chip) system that fits a NES in the size of a credit card.  These have all sorts of problems though, sound, game incompatibility, color problems, and overall bad build quality.  Since I like my games 100% authentic, both sight and sound, the only option was the original NES hardware.
Also, I want to be able to use a genuine arcade controller when my NES is hooked up to the big screen so I am doing something that has never been seen before (by me anyway). The controller part is detachable from the rest of the unit!
These were my goals for this project:
Keep it as small as possible
Make something that hasn't been done before
Maintain a good quality build
Inspire others to try something similar
I think I have accomplished all of these goals.  The final footprint is 31" High x 14 1/2" Wide x 15 1/2" Deep.  The cabinet has two unique features I've never seen.  It has the detachable controller, and it has and actual NES mounted on the monitor with a GameGenie connector soldered directly to the motherboard.  I didn't take any shortcuts with this build, and everything is strong and sturdy.  Finally, I've already had people tell me they want to build one of these!
So without further adieu, I give you The Genuine NES Bartop Arcade.
*Check out the NES rom I made to show off the cabinet (future instructable?)*
**for some reason it is showing up as a .tmp file.  Just change it to a .nes file and you should be able to run it on your emulator or PowerPak
Step 1Materials Parts and Tools
  • last photo ←
I want to start by saying that I am not a professional builder, painter, or electronics expert.  I have spent a lot of time tinkering, and a lot of time reading what other people have done.  Please take this Instructable and learn from it.  This is my first Instructable, and my first attempt at making an arcade, so I am open to constructive criticism and welcome feed back.
SAFETY
I am a huge advocate of safety.  I have never had an accident involving tools and I plan on keeping it that way.  This Instructables involves tools that can kill you if not used properly.  Some can kill you right away, some may kill you down the road.  You only have one body, take care of it.
Eye Protection
Dust mask
Gloves
Solder fume extractor
Materials
1/2" MDF - Came in a 4'x8' sheet only needed half of it
Krylon Spray Primer - Gray
Krylon Fusion Black Spray Paint
Krylon Fusion Red Spray Paint
Size 5 or 6 3/4" screws
Size 5 or 6 1 1/4" screws
Plexi/Acrylic/whatever - I don't know much about this stuff, I just had a bunch I salvaged
Wood Glue
Wood Filler
Tools
Drill - hand drill works, but a drill press is much easier
1 1/8" Spade bit - for buttons
1 1/4" Spade bit - for joystick
Counter-sink bit - I like to counter sink and pre-drill all my holes
Screwdrivers
Pliers
Wire cutters
Solder
Soldering Iron
Multimeter - for testing circuits and verifying connections
Scissors
Utility Knife - the sharper the better
Sand paper
Sanding blocks
Files
Router
Flush Trim router bit
Belt Sander
Table Saw
Circular Saw
Jigsaw
Hacksaw
Painters Tape
Parts
1 Front Loading NES
1 Arcade Joystick
6 Arcade Buttons
1 Galoob GameGenie Enhancer cartridge
1 NES controller
1 Set of speakers with built in amplifier
1 small light for marquee - I found a 13" wide Florescent light at the hardware store.
1 small powerbar - make sure it will fit in your controller box
4 rubber non-skid feet
2 Spring Roller Latches - for holding the top on
2 Latches - if you decide to make the controller detachable
Some small gauge wire - wiring the joysticks
You will also need the power adapters and av cables that came with the NES and other components.
30 comments
Mar 17, 2012. 12:18 PMjoeydavies2869 says:
How do you wire the joystick and the buttons? and where did you get the graphic for the controller box??? great ible
Mar 18, 2012. 2:56 PMjoeydavies2869 says:
wow apparently im blind i read this ible 2 before i commented on it. where is the best place to ground out the buttons?
Feb 1, 2012. 9:04 AMvonmunster says:
i love this instructables.... great job by the way... i did have one question... what about games that entail 2-Player mode? does this setup allow for 2-Players, or just 1-Player? let me know and thanx again
Aug 4, 2011. 11:35 AMzombeastly says:
SOOOOO do u accually put in a nes syestem?
kewl instructable dude!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mar 26, 2011. 5:25 AMbclayton says:
I like the overall outcome. Just a suggestion: for the Nintendo Logo, try to use window tint film. Just apply it to the plexi surface, cut out the logo, then place in a layer of red light tint film. You can get sheets of these for pennies. Looks good as is, just for another project, maybe you'll wanna give it a try.
Apr 1, 2011. 4:00 AMpjrpumpken says:
Som 1 has done this before actully 2 people before u
Apr 2, 2011. 4:25 PMpjrpumpken says:
Oh soz i didnt realiese that you use the actual nes bit good on u for not using roms
Mar 28, 2011. 11:19 AMbclayton says:
Laser cutter would be nice, but major overkill. Just an exacto knife and a stencil. Good luck.
Mar 27, 2011. 3:55 PMmary candy says:
so cool
Mar 27, 2011. 12:57 PMronanry says:
Just one question (sorry if it's already mentionned but i have not seen it) what kind of screen did you use ?
However, a wonderful instructable and a wonderful project !
You put me in mind to do the same with a Snes (famicom)
Mar 27, 2011. 11:09 AMwilhouse says:
very cool. If you were to sell it, or make one for someone, what do you think you would charge?
Mar 23, 2011. 6:15 PMmelly12 says:
Oh we all know you were really posting to yourself ;)
I can't believe that last week it was just a piece of board with 5 holes in it and now it is this! WOW! So impressed I had to vote for it! Okay, let's be honest even if I wasn't I would have voted for you but it really is quite amazing that you thought of this and made it come to life!
Mar 23, 2011. 4:01 PMCelt says:
Where did you get your joy stick assebly? that is the only part that worries me. BTW, nice idea on the internal power strip! Makes things easier to manage for me.
Mar 23, 2011. 9:02 AMslaveboy1978 says:
Dont worry, my wife does that too ..... keeps people guessing.
but I do like the work and thought that was put into this. after buiding one MAME cabinet it may be time for a NES and possibly a C-64 one in our household
Mar 22, 2011. 2:28 PMCelt says:
HAHAHAHA. Great post. I attempted something like this with an old play station, but it was accidentaly fried when I had some wires crossed. My electronics knowledge back then was limited. I don't know if I have the guts to rip into my precious....(NES) that is. Maybe one day.
Mar 23, 2011. 1:32 PMTheDarkNinja says:
... ebay my friend, grab one for cheap
Mar 23, 2011. 3:59 PMCelt says:
I now have an extra computer moniter....... Im thinking on buying a console emulator( one that plays regular NES and SNES games) at game fellas. Now that I have an ible I can properly do this!
Mar 23, 2011. 5:29 AMStereoKills says:
Nice!
Mar 22, 2011. 6:32 PMandytt11 says:
are you Chris Marquette?
great ible
Mar 22, 2011. 1:14 PMDeanGPotts says:
Brilliant, i had ideas of my own last year of something very similar, i dont have the time, money or space for one though but its good to see others have done it
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:WhatULive4(NESDEV Homebrew Competition)
Brad Bateman is a programmer, electronics hobbyist and classic Nintendo fanboy. He is currently dabbling in NES programming in 6502 assembly. He is interested in ANYTHING Nintendo related. When not...
more »
