The Graphing Calculator Survival Guide
16,145
17
21
Posted in HomeLife-skills
Introduction: The Graphing Calculator Survival Guide
If you're anything like me, you know how boring many classes at school can get. And then you know how that boredom keeps you from paying attention sometimes... Well now there's a solution. No, not actually paying attention (duh), but using your graphing calculator a little bit differently.
I know that when I first got my graphing calculator, things were confusing. So for people who are still in that stage, I tried to make this guide as basic as possible. If I didn't clarify something well enough, leave a comment about it please.
Also, this was written specifically for the TI-89 Titanium calculator. Some things might be slightly different on other calculators and you might have to figure a few things out yourself.
Step 1: Screens/Menus
I'm going to first clarify the names of a few important things you'll need here... Check the pictures.
Step 2: Notes
The easiest way to get notes on your calculator is to simply open up notepad on your computer, and type up the notes.
Then open up TI Connect (It should come on a cd with your calculator) and open up all of the files on your calculator using the 'Device Explorer' function on Ti connect.
Then simply drag your notes into the folder you want them in on your calculator. It will take a second or two for it to transfer depending on the size, and then they should be on your calculator.
To access your notes on your calculator, go the the 'Apps' menu, find notefolio, and there should be a menu. Click 'Open', then find your document.
In class, you can also open up Notefolio and manually type out a few notes (rather slowly with the keys on a calculator though). To do this, open up Notefolio from the 'Apps' menu, and start a new document, and start typing.
Step 3: Post-it Note Notes
There's a place on your graphing calculator that is very handy for hiding little slips of paper in... It's in the cover, under the ridges that hold it to your calculator...
Pretty self-explanatory what to do now...
But try to write your notes at the bottom of the post-it notes so you can slide the calculator up to look at the notes without it being obvious.
Step 4: Freeze Protection
Even though graphing calculator's are pretty amazing, they do sometimes freeze up at the most inconvenient times. To fix a freeze up on a graphing calculator, you have to remove the back up battery and the regular batteries to 'reboot' everything. Unfortunately, if you don't have a screwdriver handy at the time of the freeze, you can't do this, because there's a plastic cover screwed down over the batteries. This could really screw you up if your calculator freezes during school.
So you don't have to carry a screwdriver with you everywhere, simply remove the cover with a screwdriver at home, put the screw in the little hole above the batteries (see the picture) and put the plastic slip back on, and close it all up. Simple.
Also, when a calculator freezes, documents can be lost. In order to prevent this, you will need to archive the documents you want to keep. First, go to the Command screen. Then press the '2nd' key, then the '-' key to open up all of your files. From there, the pictures should tell the rest of the story.
Step 5: And Most Importantly... Games
So your brain doesn't shut down from the boredom of some classes, you'll need something to occupy yourself with...
Easiest way to do this is download a few games and put them on your calculator.
There are many sites dedicated to graphing calculator games right now. I find that for my Ti-89 Titanium, this site works well, although if you have a different calculator you'll need a different site of course. Google away.
Once you find a game you want to try out, download it, and find a file that looks like the ones I tagged in the picture. Usually it's right there when you open up the file. Open up Ti Connect, go to your calculator's files, and just drag the file you found over to the folder you want it in on your calculator.
To play your game/s, first go to your command screen. To do this, press the Home key. Then press the 2nd key, then the '-' key. This takes you to all of the files on your calculator. Then, locate the folder in which you put your game, then click on the game once you find it. It should now take you back to the command screen. Press enter, and the game should start up.
Have fun
A word of warning when trying out games though... Some games aren't designed very well, and they can crash your calculator easily. Also, if you (like me) have the Titanium, some regular ti-89 games will work, but others won't, and can cause your calculator to crash too. So be careful, and remember to archive what you need on your calculator when trying out games. You can also back up your games on your computer using TI Connect.
Step 6: Fin
And there you go. The ultimate note-taking and time wasting device you are allowed to use in school (most of the time at least).
Warning: Playing games on a calculator in classes besides a math class can sometimes get you labeled as a nerd/geek/loser, depending on your class mates.
But who cares? They're the ones who will get bored first since they have something against graphing calculator games.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    21 Comments
    I am having a horrible time loading notfolio and other apps any ideas please?
    instead of post-it notes write your "help" in a program
    i draw in the graph:P then i do ostupid stuff lol
     i've got a "TI-84 Silver Edition" but we barely use them.
    I currently have a TI-83+. I can't download anything as of yet, so i was wondering if there is a few recipes for games with the onboard programmer.
    You can make TI -BASIC programs on your calculator, but making an entire game with on the calculator would be tedious. However, you can create basic programs with Graphlink on your computer, and then send them to your calculator. Downloading games from the internet is easier though. If you want to learn TI-BASIC tibasic.wikia.com is great. ticalc.org is the best website to download games from imo.
    id never heard of an 89, in comparison are they better or worse than an 84+ silver edition
    Well, I've never used an 84, sorry. I've talked to people who have though, and they switched to an 89 and they prefer it. Google it and you can probably find something to compare them.
    i have a 84 plus silver edition and i love it, but looking at some of the screen shots that are there, I'm thinking that the 89+ is more advanced.
    Some one can u make a programing guide for casio calculators
    I was trying to figure out how to put games on mine. Then I realized I need to update my OS! This instructable is pretty cool. P.S. the writing on a black cover does show lightly. just don't push too hard or it might scratch perminately into the plastic.
    Step No.3 -> just writes the note ON the cover of the calculator, that way, you can just smudge them, and not get caught!
    I like the idea... Since the cover's black though it might be hard to see but you could probably find an angle to read it from. Might have to try it this year
    i don't like to memorize formulas, so i just write them on my calculator
    dissableing the apps menu was the first thing i did when i got my 89. it's a calculator, not a kids computer.
    www.ticalc.org is also a great site for games and other programs for calculators and computers
    instead of always removing the batteries (which could get you called out in the class you're trying to pay attention in), hold down (starting in this order helps the most) 2ND ON LEFT RIGHT
    thanks for the note part, but for some reason i get an error towards the brginning of the note transfer (PC to TI-89)
