A homemade potato gun that is aerosol powered and easily constructed with parts from your local hardware store for under $50 !!
Step 1: Parts and materials
It is a good idea to use schedule 80 PVC for your project.
For this project I used 4" PVC for the chamber and 2" PVC for the barrel. These pipe sizes can be changed based on availability.
Other important pieces are the :
4" cleanout with cap (Top right).
4" to 2" reducing coupling (Top Left).
4" x 4" x 2" coupling w/ sweep 90' (Middle)
2" cap (middle right)
PVC cleaner and cement
Not pictured : a BBQ grill igniter (pushbutton type)
1-40 of 66Next »
EET1982 says: Jun 9, 2013. 5:38 PM
Making mine soon. Thanks for the instructable!!!
illdoyourdrugs says: Jan 21, 2010. 6:10 PM
@ The video posted: Your going to want to put a screw through your barrel at the neck so you CANT shove the potato into the chamber DUH. Don't use a BBQ lighter there garbage and don't always ensure a fire. Use a lantern igniter. They don't fail. Sand the tip of your barrel and make it sharper to allow for the potatoes to enter easier. I added a guitar like strap to support the weight of the gun and to make it easier when twisting the lantern igniter. The best spray fuel is Static Guard. It will make those potatoes scream. Ive made plenty of these and done my research. Trial and error. Hope i helped others.
EET1982 in reply to illdoyourdrugsJun 9, 2013. 5:38 PM
Great advice. I'm about to make my own as well and from your suggestion going to go with the lantern ligniter and the strap. Going to be epic if it all works. Thanks again!
tonysoprano6379 (author) in reply to illdoyourdrugsMar 27, 2011. 5:22 AM
Wow, Thanks for the advice. I can't wait to give these suggestions a try!
illdoyourdrugs in reply to tonysoprano6379Mar 28, 2011. 12:13 AM
You reply nearly a year later hahaha.Oh well you know what they say.... better late then never! No problem.
polabearboi says: May 17, 2008. 2:39 PM
how far will this gun shoot???
rayman546 in reply to polabearboiFeb 12, 2009. 9:43 PM
Using a gun I had built previously with close to the same specifications, and ether as the fuel, we shot a potato 2700ft roughly. Measured it with a wheel tape. I live in a very small town and only about ten people total live here so we just shot down the old highway.
frankinator in reply to rayman546Mar 23, 2009. 2:26 PM
i am sorry for calling you out on that but that is almost impossible unless you were using highly combustible fuels such as acetylene. and if you were trying to use a fuel that powerful with a pvc cannon you are not the brightest individual. you must be mistaken trust me i know
mneuls in reply to frankinatorJul 14, 2011. 8:50 PM
I was getting around 800m using propane as fuel. the gun was at least double the size of the one in this build. gas chamber was 5ft x 6" and the barrell was around 9ft long made from stainless steel. I also had an oxygen tank to provide the proper fuel air ratio as well. I think it's easily possible to get well over a km with a well designed potato gun with the right wind and angle.
tonysoprano6379 (author) in reply to polabearboiMay 17, 2008. 8:02 PM
A minimum of at least a hundred yards, I have not yet tried to acurately measure the total distance. I know that the distance varies by the amount of fuel used, BUT IF YOU TRY BE CAREFUL !!!!
mneuls says: Jul 14, 2011. 8:45 PM
I found propane to be by far the best fuel, it doesn't leave stick residue on the sides of the chamber, I tubed a small home kit with oxygen and propane bottles, to eliminate the need to air out the chamber. I also find that if you gas up the chamber before pushing the potato down it compresses the gas inside and makes for a bigger bang. Ether or "liquid fire" works awesome as well.
Cobalt59 says: Jan 23, 2011. 1:13 PM
I like your evil laughs. :)
tictaclad says: Feb 10, 2010. 7:31 AM
 i couldnt find 4" pvc so i had to use abs and i still only went 3 inches....i think 4 inches is to big
tictaclad says: Feb 9, 2010. 4:58 PM
 just made one cant wait 4 it 2 dry.
Verbinguden says: Dec 23, 2009. 11:21 PM
I like those laughs in the demonstration video, lol. Great instructable.
tonysoprano6379 (author) in reply to VerbingudenJan 3, 2010. 6:21 PM
 Thank you very much.......... This was messing around on our lunchbreak at work (hence the evil laughs)
karatedude43 says: Dec 6, 2009. 1:46 PM
Hey is there anyway to make a thinner barrel and still have it work? if there is, is it possible to make a homeade rpg projectile to shoot out of it?
tonysoprano6379 (author) in reply to karatedude43Dec 6, 2009. 6:39 PM
 A thinner barrel should not be a problem........based on the availability of your parts........  You would just need a different sized reducing coupling..
I was just discussing the idea of different ammo the other day at work with my buddy......
He told me that he always uses shop rags to form a "wad" similar to muzzleloading rifle. This enables you to use anything smaller than your barrel for a projectile. (ie; golf balls)
GOOD LUCK!!!!!!!!
furby1994 says: Oct 12, 2009. 5:55 PM
where did you get schedule 80 pvc pipe from i have only ever heard of schedule 40 and thats the thickest i have seen and will schedule 40 work
bigtimmi2010 says: Mar 28, 2009. 8:07 PM
i think he ment on the wire leads, at the ends. my friend and i just built a spudzooka, and we did this, and it turned out very well
bakedjuggernaut says: Mar 4, 2008. 7:03 PM
I like the look of it man. I just went to the store bought the stuff and just put all the parts together, just waiting till tomorrow to start lighting some potatoes across town! I'm using WD-40 though, not hairspray. you use less spray, and WD is pushed out of the can with propane, so its nice. Can't wait to use it. -Home Depot, was a lil more pricey than i though it would be, but i bought a few extra stuff. but was around 60 for me..
RedneckAsian in reply to bakedjuggernautDec 20, 2008. 8:47 AM
i dont care cuz where i live there's a lowes and home depot across the street from each other
tonysoprano6379 (author) in reply to bakedjuggernautAug 7, 2008. 7:44 PM
Awesome. I am glad to inspire others to build potato guns. I know that there are alot on this site.... make another instructable with your project. I like to see other peoples projects and videos.
markymaster1 in reply to bakedjuggernautJul 19, 2008. 8:56 AM
Use hair spray, Lysol, or spray on deodorant. they stay spray longer and probably more potent with less smell. burning WD-40 smells so... try those listed.
markymaster1 in reply to bakedjuggernautJul 19, 2008. 8:54 AM
dude WD-40 doesnt ignite once it settles. it has to stay in spray form to light and since its thick oil it settles quik. use hair spray or lysol. the original spray cans work great. also for torching = )
tonysoprano6379 (author) in reply to bakedjuggernautMar 8, 2008. 1:41 PM
Glad to hear you are using my instructable as a model for your project!!!! You are the second person who has mentioned wd-40, I think I'll give it a try. !!!!!
bakedjuggernaut in reply to tonysoprano6379Mar 9, 2008. 4:40 PM
yeah, watch the hell out though, holy crap. it didn't work the first time i took it out to use. and sprayed to much, and mixed wd40 w/ hairspray cause i was wtf this thing needs to blow. then i just left it there for a weekend. came back shot it off, and damn. I had duck tape around the trigger and it flew right off nearly hit myself and burnt the hell outa my thumb, but it was awesome.
codongolev in reply to bakedjuggernautJul 9, 2008. 10:18 AM
was the barrel shooting fire?
tonysoprano6379 (author) in reply to codongolevJul 9, 2008. 6:58 PM
Yes it's awesome !!!!! When we shoot at night there is a good 2 foot flame that shoots out of the barrel!!! It Rocks!
chewit says: Sep 16, 2008. 6:04 AM
this is great and i want to build one but i`m having trouble finding the parts in the UK can anyone help???
harry_osullivan in reply to chewitNov 30, 2008. 10:58 AM
builders merchants/ plumbing supplies should have the PVC parts needed
harry_osullivan says: Nov 30, 2008. 10:57 AM
Wrap it in a sheet of Chicken wire/ hexagonal wire fencing and then coat that in Duct tape or even dip it in liquid epoxy resin or something for extra stength this thing shoots ice quite well too
tylerolso says: Oct 27, 2008. 6:55 PM
this works super duper and if you live in a urban area i wouldnt shoot it very loud and attract the police
jasonckoval says: Aug 28, 2008. 2:05 PM
Hey folks, really be careful. One thing I have seen is to wrap the combustion chamber with wire and then duct tape. The wire adds alot of strength to resist the "hoop" stress of firing. Just wrap it tightly. You can also use duct sheet metal bent into a cylinder shape. you just want to reinforce the chamber because if you use this thing it is just a matter of time before it fails. Good luck!!
Junk Mail says: Mar 20, 2008. 3:22 PM
If you sharpen the edges around the end of the barrel it makes loading much easier.
thematt3 in reply to Junk MailAug 26, 2008. 12:48 PM
I made an air cannon today and sharpend the edges and ended up with a big cut. if u sharpen the edges, USE UTILITY GLOVES TO LOAD or u will be like me. lol. =P
tonysoprano6379 (author) in reply to Junk MailMay 17, 2008. 8:02 PM
Great tip, I have had others suggest that but have not tried it yet! Thank you
twenglish1 says: Jul 19, 2008. 9:24 AM
awesome , i built one of these that was about 12 Feet long this inspired me to get it working again
tonysoprano6379 (author) in reply to twenglish1Aug 7, 2008. 7:41 PM
Glad to be of inspiration to your project!!! This is a great site with a ton of great ideas!
twenglish1 in reply to tonysoprano6379Aug 8, 2008. 9:28 AM
yah it is this is where i got most of my ideas
1-40 of 66Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
