3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Great Potato Cannon
A homemade potato gun that is aerosol powered and easily constructed with parts from your local hardware store for under $50 !!
Step 1Parts and materials
Parts and materials
It is a good idea to use schedule 80 PVC for your project.
For this project I used 4" PVC for the chamber and 2" PVC for the barrel. These pipe sizes can be changed based on availability.
Other important pieces are the :
4" cleanout with cap (Top right).
4" to 2" reducing coupling (Top Left).
4" x 4" x 2" coupling w/ sweep 90' (Middle)
2" cap (middle right)
PVC cleaner and cement
Not pictured : a BBQ grill igniter (pushbutton type)
64 comments
1-40 of 64next »
May 17, 2008. 2:39 PMpolabearboi says:
how far will this gun shoot???
Feb 12, 2009. 9:43 PMrayman546 says:
Using a gun I had built previously with close to the same specifications, and ether as the fuel, we shot a potato 2700ft roughly. Measured it with a wheel tape. I live in a very small town and only about ten people total live here so we just shot down the old highway.
Mar 23, 2009. 2:26 PMfrankinator says:
i am sorry for calling you out on that but that is almost impossible unless you were using highly combustible fuels such as acetylene. and if you were trying to use a fuel that powerful with a pvc cannon you are not the brightest individual. you must be mistaken trust me i know
Jul 14, 2011. 8:50 PMmneuls says:
I was getting around 800m using propane as fuel. the gun was at least double the size of the one in this build. gas chamber was 5ft x 6" and the barrell was around 9ft long made from stainless steel. I also had an oxygen tank to provide the proper fuel air ratio as well. I think it's easily possible to get well over a km with a well designed potato gun with the right wind and angle.
Jul 14, 2011. 8:45 PMmneuls says:
I found propane to be by far the best fuel, it doesn't leave stick residue on the sides of the chamber, I tubed a small home kit with oxygen and propane bottles, to eliminate the need to air out the chamber. I also find that if you gas up the chamber before pushing the potato down it compresses the gas inside and makes for a bigger bang. Ether or "liquid fire" works awesome as well.
Jan 21, 2010. 6:10 PMilldoyourdrugs says:
@ The video posted: Your going to want to put a screw through your barrel at the neck so you CANT shove the potato into the chamber DUH. Don't use a BBQ lighter there garbage and don't always ensure a fire. Use a lantern igniter. They don't fail. Sand the tip of your barrel and make it sharper to allow for the potatoes to enter easier. I added a guitar like strap to support the weight of the gun and to make it easier when twisting the lantern igniter. The best spray fuel is Static Guard. It will make those potatoes scream. Ive made plenty of these and done my research. Trial and error. Hope i helped others.
Mar 28, 2011. 12:13 AMilldoyourdrugs says:
You reply nearly a year later hahaha.Oh well you know what they say.... better late then never! No problem.
Jan 23, 2011. 1:13 PMCobalt59 says:
I like your evil laughs. :)
Feb 10, 2010. 7:31 AMtictaclad says:
 i couldnt find 4" pvc so i had to use abs and i still only went 3 inches....i think 4 inches is to big
Feb 9, 2010. 4:58 PMtictaclad says:
 just made one cant wait 4 it 2 dry.
Dec 23, 2009. 11:21 PMVerbinguden says:
I like those laughs in the demonstration video, lol. Great instructable.
Dec 6, 2009. 1:46 PMkaratedude43 says:
Hey is there anyway to make a thinner barrel and still have it work? if there is, is it possible to make a homeade rpg projectile to shoot out of it?
Oct 12, 2009. 5:55 PMfurby1994 says:
where did you get schedule 80 pvc pipe from i have only ever heard of schedule 40 and thats the thickest i have seen and will schedule 40 work
Mar 28, 2009. 8:07 PMbigtimmi2010 says:
i think he ment on the wire leads, at the ends. my friend and i just built a spudzooka, and we did this, and it turned out very well
Mar 4, 2008. 7:03 PMbakedjuggernaut says:
I like the look of it man. I just went to the store bought the stuff and just put all the parts together, just waiting till tomorrow to start lighting some potatoes across town! I'm using WD-40 though, not hairspray. you use less spray, and WD is pushed out of the can with propane, so its nice. Can't wait to use it. -Home Depot, was a lil more pricey than i though it would be, but i bought a few extra stuff. but was around 60 for me..
Dec 20, 2008. 8:47 AMRedneckAsian says:
i dont care cuz where i live there's a lowes and home depot across the street from each other
Jul 19, 2008. 8:56 AMmarkymaster1 says:
Use hair spray, Lysol, or spray on deodorant. they stay spray longer and probably more potent with less smell. burning WD-40 smells so... try those listed.
Jul 19, 2008. 8:54 AMmarkymaster1 says:
dude WD-40 doesnt ignite once it settles. it has to stay in spray form to light and since its thick oil it settles quik. use hair spray or lysol. the original spray cans work great. also for torching = )
Mar 9, 2008. 4:40 PMbakedjuggernaut says:
yeah, watch the hell out though, holy crap. it didn't work the first time i took it out to use. and sprayed to much, and mixed wd40 w/ hairspray cause i was wtf this thing needs to blow. then i just left it there for a weekend. came back shot it off, and damn. I had duck tape around the trigger and it flew right off nearly hit myself and burnt the hell outa my thumb, but it was awesome.
Jul 9, 2008. 10:18 AMcodongolev says:
was the barrel shooting fire?
Sep 16, 2008. 6:04 AMchewit says:
this is great and i want to build one but i`m having trouble finding the parts in the UK can anyone help???
Nov 30, 2008. 10:58 AMharry_osullivan says:
builders merchants/ plumbing supplies should have the PVC parts needed
Nov 30, 2008. 10:57 AMharry_osullivan says:
Wrap it in a sheet of Chicken wire/ hexagonal wire fencing and then coat that in Duct tape or even dip it in liquid epoxy resin or something for extra stength this thing shoots ice quite well too
Oct 27, 2008. 6:55 PMtylerolso says:
this works super duper and if you live in a urban area i wouldnt shoot it very loud and attract the police
Aug 28, 2008. 2:05 PMjasonckoval says:
Hey folks, really be careful. One thing I have seen is to wrap the combustion chamber with wire and then duct tape. The wire adds alot of strength to resist the "hoop" stress of firing. Just wrap it tightly. You can also use duct sheet metal bent into a cylinder shape. you just want to reinforce the chamber because if you use this thing it is just a matter of time before it fails. Good luck!!
Mar 20, 2008. 3:22 PMJunk Mail says:
If you sharpen the edges around the end of the barrel it makes loading much easier.
Aug 26, 2008. 12:48 PMthematt3 says:
I made an air cannon today and sharpend the edges and ended up with a big cut. if u sharpen the edges, USE UTILITY GLOVES TO LOAD or u will be like me. lol. =P
Jul 19, 2008. 9:24 AMtwenglish1 says:
awesome , i built one of these that was about 12 Feet long this inspired me to get it working again
Aug 8, 2008. 9:28 AMtwenglish1 says:
yah it is this is where i got most of my ideas
Jul 26, 2008. 10:54 PMmokano667 says:
its cheaper at lowes i got evrythiong excludeing the primer and cement and the ignitor for only 15 bucks
Aug 8, 2008. 9:27 AMtwenglish1 says:
my ignitor was on $12
1-40 of 64next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:tonysoprano6379
