3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Green Helmet (Solar powered, safety lit, weatherproof bike helmet.)
  • last photo ←
A solar powered, trickle-charged, weatherproof, safety bike helmet with changeable parts.
> See 45 second video of helmet
> 2-minute video of construction and use
> Charge time: 5-8 hours in full sunlight to charge 4 AA batteries. I used 3 AAA batteries, so it charges in more like 4 hours. It will charge in bright cloud cover as well.
> Runtime being tested, but so far, seems like several hours.
> Replaceable 5 or 10mm LEDs, flashing or not, in O ring sealed mounts.
> Flexible weatherproof solar panel.
> Detachable batteries and panel for use as a AAA battery charger for camping equipment like headlamps that use 3AAA batteries.
> Removable the AAA batteries can be easily taken out and charged in wall if needed, or regular AAAs can be used.
I thought this would be a well-suited application of solar powered trickle charge panels. I only ride at night about an hour a week, so during the day the helmet can sit in a window and charge. Helmet mounted lights also free me from having lights mounted on my bike that need to be detached to keep from being stolen. It works in the rain and so far is always charged when I need it.
This project could be done in many different ways and I spent a lot of time trying different parts and ideas. The key breakthroughs for me were to use 3 AAA batteries, vs the 4AA's that came with the Solar Panel because they were a better balance of weight to the right amount of power and milliamps. I ended up using a simple soft case Velcro wrapped to the helmet, and relied heavily on Black Shoe Goo! (I think it's the new duct tape). Most of the work was getting an easy rapid prototype idea to work rain or shine, for months on end, and be versatile with replaceable parts. I kept it flat black because the helmet is flat black, so chips don't show. And I'm in New York City, where black is the default color.
Good luck! Let me know if you come up with better ideas.
Caleb John Clark. Made at NYU, Tisch School Of The Arts, ITP dept. for Build in Despina Papadopoulo's Softness of Things class
Oct. Nov. 2007
> My Portfolio
> my TechTrek.Tv show
Step 1Parts & Tools
Parts & Tools
Tools: Basic electronics tools. Wire cutters/strippers. Sander or file. Heat gun. Electrical tape. Solder iron. Breadboard might be nice for testing, but not needed.
Parts:
Helmet: Bern black Brentwood with visor pads for summer: http://www.bernunlimited.com/2007/brentwood.html
Solar Charger: Flexible Solar Battery Charger SolLite-4AA by Silicon Solar. (I used a different case with 3 AAA batteries). http://www.siliconsolar.com/Flexible-Solar-Battery-Charger-SolLite-4AA-p-16199.html
LEDs
> 2, Giant 10mm Rainbow Flashing LED: Flash slow, then fast, through red, green and blue. Electronic Goldmine: http://www.goldmine-elec-products.com/prodinfo.asp?number=G16226
Or if you want a longer run time, use regular single color flashing 5mm bulb, say green in color from the sites below.
> 2, Red Clear 10mm Flashing LEDs. Electronic Express: http://www.elexp.com/opt_6bid.htm
> 2, Yellow Clear 10mm Flashing LED. Electronic Express: http://www.elexp.com/opt_6bid.htm
LED Mounts
Waterproof, replaceable bulb mounts. Takes 5mm or 10mm bulbs.
6, White 10mm 24 inch wired mounts: 593-CNX460X24124 CNX460-X02-4-1-24 VCC LED Lens Mounts from Mouser Inc. http://www.mouser.com/search/ProductDetail.aspx?R=CNX460-X02-4-1-24virtualkey59300000virtualkey593-CNX460X24124
LED Mount Lenses
Clear Water Tight O-ring Fresnel lenses: 593-HMS462CTP HMS462CTP VCC LED Lens Mounts: Mouser Inc. http://www.mouser.com/search/ProductDetail.aspx?R=HMS462CTPvirtualkey59300000virtualkey593-HMS462CTP
Battery holder/switch
Radio Shack: "AAA" Battery Holder (Holds 3 Batteries)
Item #: AC-1100-270-0412
http://www.trossenrobotics.com/store/p/3544--AAA-Battery-Holder-Holds-3-Batteries-.aspx
Switch: Radio Shack DPDT Submini Slide Switch. Model: 275-407
http://www.radioshack.com/product/index.jsp?productId=2062491&cp=2032058.2032230.2032278&pg=2&parentPage=family
Batteries
3 high quality rechargeable AAAs, Ni-Cad seems the choice of lots of solar products.
9 volt battery snap connectors
2, nine volt battery connectors. http://www.radioshack.com/sm-fully-insulated-9v-battery-snap-connectors--pi-2062219.html
Soft Case: Case Logic MP3 Mini Disc Player Shuttle: http://www.caselogic.com/small_mp3_player_shuttle/product_detail/index.cfm?modelid=56457
Black Shoe Goo: To fill in around mounts and reinforce/waterproof solar panel connectors, and soldering and switch on battery holder: http://lifehacker.com/software/household/shoe-goo-super-glue-157137.php
Standard 'gap filling" super glue for LED pre-Shoe Goo mounting, wiring and reinforcing Velcro edges
Standard Black Double sided Velcro
Reflective Velcro bike wrap
black shrink tubing (electronic stores)
Krylon ultra flat black spray paint. (hardware stores, could use gloss Krylon "Fusion" paint too)
61 comments
1-40 of 61next »
Oct 26, 2011. 8:10 PMedina2015 says:
So if you do wreck the solar panells will get ruined right?
Aug 2, 2008. 3:07 AMpellepeloton says:
Is this a safe helmet I ask? First, it looks like an old helmet without slippery hard shell? I have seen a lot of helmets where the original plastic cover has fallen off so it only has polystyrene shell left. Hit your head into asphalt and it does not slide but grips and twists your neck!! I will not speculate what will happen next. Secondly, those added modifications stick out, and in the case of hopefully unlikely accident or even hitting a tree with your helmet, it will get caught causing your head to twist? The primary purpose of any helmet is to protect the wearer from shocks and reduce the possible injury and any modification added into helmets may compromise these.
Aug 28, 2008. 12:23 AMYerboogieman says:
i dont even wear a helmet.
Nov 30, 2009. 12:09 PMYellowRex says:
 I hope someone deserving gets your organs.
No helmet bikers (motor or otherwise) make the best donors.
Nov 30, 2009. 6:41 PMYerboogieman says:
No kidding. If you can find a helmet that fits my head, i will buy it.
Sep 2, 2008. 4:03 PMXellers says:
And you claim this as if it were a good thing?
Sep 2, 2008. 6:00 PMYerboogieman says:
i don't know, but i just saved a bunch of money on my car in....im using the new Google chrome. they're uncomfortable and hurt my head, although its probably going to hurt my head even more when i crash on pavement. its a lose/lose situation.
Sep 24, 2008. 5:13 PMjillg says:
i just got google chrome. waaaaaay better than microsoft internet explorer
Feb 14, 2009. 12:25 PMNetReaper says:
WTH why use either when u got firefox
Jan 19, 2009. 8:29 PMYerboogieman says:
Firefox is better.
agreed
Aug 14, 2008. 5:42 PMRedgerr says:
it looks prety safe to me :O i imagin that it is one of those really expenceive ones that they modified, it looks like one of mine. also it could be a skatebord helmet, they are made differently but do about the same thing :O hope i helped :O
Nov 15, 2007. 4:07 PMcallmeshane says:
This is actually really well done... Pity someone isn't making helmets with thin recess's in them to take a a couple of AAA batteries. I ride my bike all the time... and it's great.... BUT.. I don't agree with bad (read exceedingly stupid) fashion trends - such as using "all black" helmets (and other clothing) on bicycles, ESPECIALLY at night.... Of all the cumulative things that you can do to keep yourself from getting run over, wearing black or dark colored clothing, this is probably the dumbest, along with no lights at all. Once many years ago, there was a new industrial estate going up near where I lived. And it had a stretch of dead flat very wide and absolutely straight and mostly unlit road... about 3km of it. So no people, no cars, no houses... no cops.... and in the middle of the night...... So I opened the motorbike up a bit... And my bike was as loud as.... with the throttle opened up - a tad... I had my lights on and everything..... And right in the middle of the road, some idiot of a kid, with NO lights, NO reflectors, WEARING BLACK pants and sweater and helmet... This idiot rode off the footpath and straight across the road - right into my path.... I was only speeding a little bit...... not much... And I had to BRAKE HARD and SWERVE to stop from running right into him..... And the thing is that because of the lack of lights and the way he was dressed, and he came across the road from the footpath, in an unlit area..... I was not able to see him, until he was just about wrapped around the front of my motorbike...... I still to this day, regret not having gotten off the bike and having beaten the daylights out of them, instead of coming back to yell at him.... "Get some some fucking lights" So just because all the other idiots use black colored helmets, doesn't mean you have to as well.... The trend or fashion for wearing BLACK helmets, is a stupid thing for stupid people. SAFE cycling counts, High visibility and being EASY to see, make for a lot of survival bonus points. Accumulate them.
Apr 30, 2009. 5:00 PMRimwulf says:
I had black jacket that I wore but it was striped with gray reflector material so I was seen.
Nov 18, 2007. 5:56 AMcallmeshane says:
This kid on the bike in all black with no lights, on the unlit street.... he came fast from the side of the road and I had like a second or so of vision to brake and swerve.....
If had not of braked HARD and swerved I would have hit him square on and he WOULD have died..... and I would have wrecked my bike, probably have hurt myself a bit and then had heaps of problems with the cops and the paperwork and all that.... and these are MAJOR hassles I just don't need.....
My bike is a BIG BMW Desert bike with crashbars and all.... and it has pretty good head lights...
Black clothing - it almost TOTALLY absorbs light.....
Toss in background lighting and other distractions and car drivers generally are going to have a hard time seeing you, until you become a hood ornament.
One of the BEST night time clothing accessories is to go to the clothing recyclers, and buy some larger BRIGHT WHITE cotton business shirts....
They fit over everything, they ARE highly visible and they are cheap...
A few of the red and white and yellow prismatic reflective tape strips on the WHITE helmet...
Toss in front, side and rear reflectors and good head and tail lights...
And some reflectors in the spokes.....
Bicycle Victoria is a self organised collective of bicycle groups and it runs some big shows.....
And even they are pushing to crunch people who ride without lights... Although I think fining people is unproductive, and making them pay for a NEW set of lights, is productive, never the less what I once saw - like a FOOL, as impingements upon my liberties and intelligence, that these "safety things" are generally well thought out, practical and very good things to do and have.
The stats for fatal and serious injuries without lights are pretty bad......
http://www.bv.com.au/bikes-and-riding/40519/
Increase the fine for riders without lights
Bicycle Victoria today has called on the Victoria Police to increase the penalty for cyclists riding without lights.
The call, on the shortest day of the year, comes after a recent Bicycle Victoria survey revealed that more than a quarter of bike riders are riding on roads at night without proper bike lights.
Despite a three-year campaign to get riders to use lights, Bicycle Victoria is disappointed that there has been no change in the proportion of riders without lights in the run up to the shortest day of the year.
Harry Barber, CEO of Bicycle Victoria said today, â€We are now calling on the police to raise the fine to one penalty point or $108 for riders who do not have working lights at night.â€
The current fine is half a penalty point - $54.
Mr Barber said a higher deterrent was needed to make riders understand that riding at night without lights increases the risk of collisions and road trauma.
â€Our surveys indicate that around a third of all fatal collisions are related to dark conditions,†said Mr Barber.
In Victoria, between 2000 and 2005, a quarter of all collisions (23.56%) leading to riders being killed or hospitalised were in dark conditions.
  • In 2004 four of the eight cycle fatalities occurred at night or in semi-darkness and involved cyclists riding without lights or with inadequate lighting. (VicRoads June 2006)
  • In 2005 none of the seven fatalities were associated with lights or light conditions
  • In 2006 five of the thirteen cycle fatalities occurred at night or in semi-darkness
A survey of 4 500 drivers in Queensland confirmed that motorists find it frustrating when bike riders don’t use lights at night. The survey (RACQ October 2006) put riders without lights at night at 7th on the top ten annoying things for motorists. In this survey, riding at night without lights was the bike rider behaviour that was most annoying for drivers.
This is a good read... a little superficial in comparisions..
http://www.vicroads.vic.gov.au/NR/rdonlyres/88D0CF95-19BF-426F-A5DC-DE7255BFFF56/0/CycVisibility.pdf
Feb 14, 2009. 12:27 PMNetReaper says:
spaz much?
Jul 27, 2008. 10:48 PMA good name says:
Dude, chill out. Wearing a black helmet isn't going to kill you. Wearing all black on a black bike without reflectors or lights is. Just because the guy's helmet is black, you don't need to freak out on him.
Aug 22, 2009. 4:56 AMSpook-rabbit says:
Not to mention those light on the helmet which were the focus of the instructable. Why are we worrying that he used a color to blend in with the SHOE GOO?
Nov 16, 2007. 1:50 PMnjzammit says:
i agree with what shane is saying becuase you won't see them at night.. aspeciaaly this which is a matt black what i recommend is some glow in the dark tape and make a couple of lines, just to make it a bit more visible.
Nov 16, 2007. 3:29 PMfungus amungus says:
glow in the dark tape is useless. I'd recommend some of the 3M reflective tape. You can get it in glossy black so it won't look weird.
Nov 17, 2007. 1:49 PMnjzammit says:
i wanted to say reflective tape sorry.. ps 10x for pointing it out...
Aug 19, 2008. 9:50 PMBeanGolem says:
There are many places online to get some killer any-color-you-want reflective tape. Even black. hah. So in the day time it blends in perfectly but at night it lights up white in headlights.
Nov 16, 2007. 11:02 AMfungus amungus says:
Yow, that was a bit of a hefty rant, but it's true, too many people ride wearing all-black and no lights or reflectors at night. I call them bike ninjas and there are lots of them in SF. Some of the worst offenders are those who ride with a blinkie on their messenger bag and then ride with the bag high up enough so that the blinkie faces straight up and does nothing. What's so tough about mounting it on the bike?
Nov 16, 2007. 1:53 PMnjzammit says:
if you call them ninjas.. i'll call them Kamikaze!! i think some mountain bikers think it's makes them look uncool to have lights on a bike.. well if you are reading.. ITS MUCH MORE UNCOOL IF YOU END UP WITH A DOZEN BROKEN BONES AFTER AN ACCIDENT!!!
Jan 19, 2009. 7:56 AMFaqMan says:
Good job on this its safe reusable and power its self.
Dec 4, 2008. 2:29 PMJellyWoo says:
cool, how much did the solar panel cost?
Dec 5, 2008. 12:38 PMJellyWoo says:
cool, thanks.
Sep 25, 2008. 11:34 PMagis68 says:
Nice job pal but but useless......because yes the light is ok but what waste of the helmet!!!!.....ts....ts.......ts
Jul 27, 2008. 3:30 PMBisquick the ninja says:
If callmeshane was not being stupid HE wouldn't have had to worry about it!! Did you ever think that he might have been a ninja trying not to be seen by spy satellites!!!??? If you were a ninja hunter and you saw some freak running down the street wearing reflective tape on his back in the shape of a target wouldn't you feel compelled to shoot him!????!!!!!?!?!?1 Dude! Don't change a thing calebjc! Except next time add some tear gas that shoots out the back so if someone is chasing you on there bike you can just push a button and make them cry like communist pansies!!!!!!!!!!!!!!!!!!!!!! ! ! ! ! ! ! ! ! ! ! !!!!! !!! !! ! !
Jul 27, 2008. 3:20 PMBisquick the ninja says:
I'm liking the black!! it's perfect for beginning ninjas who don;t want to hurt themselves buy falling out of a tree on there heads!
Jul 27, 2008. 12:10 PMfoxtrot4697 says:
try making a wind power one.when you're biking the breeze will spin the spinny thingy
Nov 30, 2007. 11:09 AMteeps says:
Really great instructable! Just wanted to give a heads up that these helmets can be found for way below MSRP over at Sierra Trading Post
Nov 20, 2007. 4:14 PMbofthem says:
Would you consider submitting this to the Mashup contest?
{instructables.com/id/How-to-Enter-the-Instructables-and-ReadyMade-Mash-/?ALLSTEPS}
Maybe the laser cutter contest too?
Nov 16, 2007. 11:09 PMZetheros says:
you know, it seems that every time I fall from a bike, it's near impossible to land on your head. usually it's either the chin, the elbows, etc.
Nov 16, 2007. 4:55 PMpellepeloton says:
Is it safe in case of accident? Safety is compromised after modifications! First : as someone pointed out it is black, not making the helmet visible on some conditions? Second: is that bare polystyrene helmet painted black. Good helmets have hard sliding surface which means that if you hit your head to asphalt it will slide and not stick breaking your neck! Third: Any attachment like the solar panel and battery compartment could cause helmet getting caught in case of accident. I have broken my both collarbones on cycling separate accidents and would not risk having a head injury if I can help it.
Nov 15, 2007. 5:42 PMlarrymroy says:
Your setup renders the helmet null. The attachments will easily penetrate the helmet in an accident, making it useless. Thus, turning the rider into a memory.
1-40 of 61next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:calebjc(My Portfolio)
