The Green Helmet (Solar powered, safety lit, weatherproof bike helmet.)
Step 1Parts & Tools
Parts & Tools
Tools: Basic electronics tools. Wire cutters/strippers. Sander or file. Heat gun. Electrical tape. Solder iron. Breadboard might be nice for testing, but not needed.
Parts:
Helmet: Bern black Brentwood with visor pads for summer: http://www.bernunlimited.com/2007/brentwood.html
Solar Charger: Flexible Solar Battery Charger SolLite-4AA by Silicon Solar. (I used a different case with 3 AAA batteries). http://www.siliconsolar.com/Flexible-Solar-Battery-Charger-SolLite-4AA-p-16199.html
LEDs
> 2, Giant 10mm Rainbow Flashing LED: Flash slow, then fast, through red, green and blue. Electronic Goldmine: http://www.goldmine-elec-products.com/prodinfo.asp?number=G16226
Or if you want a longer run time, use regular single color flashing 5mm bulb, say green in color from the sites below.
> 2, Red Clear 10mm Flashing LEDs. Electronic Express: http://www.elexp.com/opt_6bid.htm
> 2, Yellow Clear 10mm Flashing LED. Electronic Express: http://www.elexp.com/opt_6bid.htm
LED Mounts
Waterproof, replaceable bulb mounts. Takes 5mm or 10mm bulbs.
6, White 10mm 24 inch wired mounts: 593-CNX460X24124 CNX460-X02-4-1-24 VCC LED Lens Mounts from Mouser Inc. http://www.mouser.com/search/ProductDetail.aspx?R=CNX460-X02-4-1-24virtualkey59300000virtualkey593-CNX460X24124
LED Mount Lenses
Clear Water Tight O-ring Fresnel lenses: 593-HMS462CTP HMS462CTP VCC LED Lens Mounts: Mouser Inc. http://www.mouser.com/search/ProductDetail.aspx?R=HMS462CTPvirtualkey59300000virtualkey593-HMS462CTP
Battery holder/switch
Radio Shack: "AAA" Battery Holder (Holds 3 Batteries)
Item #: AC-1100-270-0412
http://www.trossenrobotics.com/store/p/3544--AAA-Battery-Holder-Holds-3-Batteries-.aspx
Switch: Radio Shack DPDT Submini Slide Switch. Model: 275-407
http://www.radioshack.com/product/index.jsp?productId=2062491&cp=2032058.2032230.2032278&pg=2&parentPage=family
Batteries
3 high quality rechargeable AAAs, Ni-Cad seems the choice of lots of solar products.
9 volt battery snap connectors
2, nine volt battery connectors. http://www.radioshack.com/sm-fully-insulated-9v-battery-snap-connectors--pi-2062219.html
Soft Case: Case Logic MP3 Mini Disc Player Shuttle: http://www.caselogic.com/small_mp3_player_shuttle/product_detail/index.cfm?modelid=56457
Black Shoe Goo: To fill in around mounts and reinforce/waterproof solar panel connectors, and soldering and switch on battery holder: http://lifehacker.com/software/household/shoe-goo-super-glue-157137.php
Standard 'gap filling" super glue for LED pre-Shoe Goo mounting, wiring and reinforcing Velcro edges
Standard Black Double sided Velcro
Reflective Velcro bike wrap
black shrink tubing (electronic stores)
Krylon ultra flat black spray paint. (hardware stores, could use gloss Krylon "Fusion" paint too)
2 comments
Nov 14, 2007. 9:41 PMcsiprun says:
Hey, do the visor and ear pads detach on that helmet?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:calebjc(My Portfolio)
