It has a green twist, because It is a Green Twist!
This Instructable shows you how to build your very own Green Twist Machine, Power Generator!
Maybe we could all build giant flywheels under our homes, that are powered-up-to-speed by green-power (probably solar or wind) during the day, that provide power throughout the night! That's what I'm talkin' about!
Three major principles at work, here.
A.) Almost any old motor can be reclaimed and used as a power-generator.
B.) Heavy flywheels can store and give-back energy.
C.) The world would be a better place if I won an Epilog Zing Laser Etcher from intructables.com!
Vote for Hope, with The Green Twist Machine!
Because flywheel-energy-storage, and energy-generation, can play a big part in our energy-efficient futures, I believe this is an important instructable to help demonstrate these techniques to future-builders and tinkerers; and well worth every effort put into it. This is not a quick instructable! (Weeks of my spare time have gone into this.) And, it's not a simple instructable, either; but also not very complex. I have tried to err on the side of providing too much information, rather than not enough. So, forgive me if there are redundant notes, photos or descriptions.
Standing at 6-feet, 3-inches tall, this giant hand-cranked flywheel power-generator and battery-charger can also be used to power other devices with similar requirements; such as small radios, lights, certain cell-phones and mp3 players, hand-warmers; the list goes on. It can be used to create amazing spin-art and surprisingly 3-Dimensional-looking photographic effects, too; simultaneously! How green is that!? Or, use it as a giant rotation-table for painting or working on your projects. There are many other uses for a giant thirty-six-inch spinning table. Maybe a giant record player; or spinning lights; as a grinding wheel; disk sander... ideas are welcome!
Best of all, it is very green-friendly, and generates electricity up to 5-volts DC, 190mA. And, because of the heavy flywheel approach, it spins for up to 5-minutes after a just few seconds of cranking! That might not seem like much time. But, a lot of electricity can be generated in a short time, while creating spin-art. And, it's pretty easy to get spinning; about five quick turns and you're off and running.
Get ready to have some fun while generating electricity and creating art, at the same time!
Sincerely,
FeedTheGrid!
Remove these ads by
Signing UpStep 1: Materials and Tools Needed
Materials
Glitter Glue
Magic Markers
PVC Plastic Pipe: for a crank-handle; aprox. six-inches. (I repurposed a Dewalt toolbox handle.)
printable transparencies (1)
White 10mm LED's (9)
Paint (Gold and Green)
large paper clip (1)
old telephone wire (1)
twenty-inches of 12-gauge house-wire
a cheap 5x7-inch photo frame
Copper Sheeting, 12 by 40-inches
One Foam-Rubber squeeze-ball (for the hand-brake)
three-quarter-inch copper Pipe (6-feet)
three-quarter-inch copper elbows (two 45-degree and two 90-degree, )
three-quarter-inch copper T-joint (1)
three-quarter-inch copper cap (1)
Shipping-Tape or Duct-Tape
Electrical Tape
Two large round flat things (I used two 36-inch wood table tops I found for FREE on Craigslist).
A few small pieces of wood (to mount the small DC motor and build light boxes and "Green Twist" frame).
Some sort of strong base (I used the base of an old kitchenette table from my garage).
An old motor, or set of bearings, like from an old office chair. I got this motor from an old air-conditioner destined for the land-fill (Green Friendly).
a 3-double-A Battery-holder with switch (1)
Diode (1)
Resistor (quarter-watt, 100ohm) (1)
small magnets (quarter-inch, cylindrical) (3)
L-Bracket (1) to mount the hand-brake
Small washers for the hand-brake L-Bracket (6)
Some woodscrews (24)
Tools
Craft knife
Utility knife
Wire strippers
Rubber Mallet
Tin Snips
Stapler and staples
Hand-drill with drill-bits, circle-drill bits, and a center-drill-bit
Miter-box and saw
Metal file
Round needle-file
Screwdriver
drafting ruler
tape measure
Paintbrush
Multi-Meter (volt-ohm meter)
Sandpaper
Visit Our Store »
Go Pro Today »
Excellent Instructable!
Now I know for sure that I won't win the laser cutter... I hope I get the macbook....
This is my entry: http://www.instructables.com/id/Solar-DS-quotLightquot-Redone-and-Greatly-Impr/
There are a couple of directions I'd love to see this go-
- the aforementioned spring tensioner for constant motor-flywheel contact
- some sort of non-human-powered drive system- wire up a solar panel or wind generator to the motor to spin up the flywheel?
- a little bit of maths about how much energy you can usefully store (might do that myself)
- a bigger badder version with a "plate stack" of flywheels mounted on ball bearings
- carbon fibre, lead and unobtainium flywheels that weigh 150kg each and can spin at 100,000 RPM (might not be quite so easy)
Anyhoo, you have my vote for the competition on the SOLE CONDITION that you use the laser cutter to build Green Twist Mk. 2.Rotational kinetic energy is 1/2*I*w2
where I = mass * radius2 for an optimal flywheel with all of its weight positioned around the outside.
And w is radians per second (which is rpm * 2pi / 60)
So, for a hypothetical 150kg flywheel with a (huge) 1 meter radius, spinning at 100,000 rpm would be:
0.5*150*12*(100,000*2pi/60)2
=8.2E9 joules
=8.2E6 kilojoules (aka kilowatt-seconds)
/60/60 = 2300 kilowatt-hours, or enough to power a typical house for a few months. Unfortunately, according to Wikipedia, you could never build such a massive flywheel spinning that fast with any known materials. (The edges would be moving 10 km per second!) The state of the art (from the Wikipedia flywheel page) seems to be 0.13 kilowatt-hours per kilogram, so 2 kWh for a 150 kg flywheel, enough to power a house for under a day.
(It would end up being really expensive given that you would need magnetic bearings, etc. for a 150kg flywheel)
A stack of ten at ten times the rotational speed (not unreasonable, but more engineering certainly) would hold a thousand times the energy, but that's still only 36,000 joules or 10 watt-hours. I guess without magnetic bearings and unobtanium flywheels this isn't going to be practical for energy storage.
