3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Handsewn Sprits'l
Step 3Lay It Out
Lay It Out
Start by setting a line for the luff, just put a pin in the floor and stretch a line of string to another, 6 feet apart. In the same way you made the drawing you'll need to lay out the pattern for the sail. If you havn't got two tape measures just measure the string from the last point you laid down to the right length and then measure the diagonal with the tape to get the location of the pin. Measure 1 and 3/8 of an inch out from the leech and set another line, going just past the head and foot.
Once the sail outline has been set up on the floor, lay down your material. Start with the selvage edge against the outer leech string you laid out. Roll out the fabric until it goes beyond the head and foot at least 6 inches. Then cut the fabric and lay the rest along the edge of what you just laid down.
Mark the Leech with a fabric pencil.
Using a carpenters square measure into the sail from the leech and mark a line from head to foot at 11 and 1/2, 12, and 12 and 1/2 inches. Fold along the 12 inch mark so that the 11 and 1/2 and the 12 and 1/2 inch marks meet. Put pins in along the seam.
The other false seams will be measured, folded and pinned in the same manner.
Where the two peices of fabric come together make a 1/4 inch hem and overlap the two peices 1/2 an inch, pin them together.
Now that you have one big peice of fabric lay it over the outline and mark the other 3 sides.
For the bottom mark the straight line you laid down, then from the center measure down 2 inches. Use a batton or webbing to create a smooth curve.
Mark the space between the leech and the outer line at 1/4, 1/2, 1&1/4, and 1&3/8. Cut the material from the sail at the 1/4 inch mark. Then make a strip from the excess by cutting at the 1 and 3/8" mark. Fold the strip on the marks and you should have a 5/8 inch strip with two 1/4 inch hems. This will be the tabling for the leech. Use the fabric pencil and mark the sail and strip with the word leech.
In the same way measure out from the luff 1/4, 1/2, 2, and 2 and 1/4 inches and mark the lines. Cut the strip from the sail at the 1/4 inch mark and then at the 2 and 1/4 inch mark. Fold the strip on the lines and you should have a 1 and 1/2 inch strip with 1/4 inch hems. Label the strip and the sail Luff.
For the Head and Foot measure out 1/4 inch and cut off the excess. When you unfold the false seams the cut edge of the material will be jagged. Just move towards the center of the excess and draw a straight line, keeping the fabric weave going the same direction as on the sail. From this line make a strip 1 and 1/2 inches wide with an extra 1/4 inch on either side to fold under as a hem.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:notjustsomeone
