3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Handsewn Sprits'l
Step 4The Flat Stich
The Flat Stich
In stitching I'm assuming you're right handed, for you southpaws just do everything in the opposite direction. Adapt and overcome.
The first thing you'll need to sew is the seams. To do this use a flat stitch.
Attach the sailhook to something at your right about the same height or slightly lower than your thigh. Sit facing slightly away from the sailhook anchor, just out of reach of the hook, don't want holes in your leg.
Take an end of your thread and draw it out about the distance from your work to where your hand is extended, double it. Cut off that peice of thread, thread your needle, then pass the thread over beeswax until it's well coated, the two peices should stick together.
You'll be stitching from right to left. Start just outside of the seam, insert the needle and bring it up through the inside of the seam. Leave an inch or two of the thread sticking out and sew over it as you progress. When you run out of thread, just leave an inch or two, rethread your needle, start about where you left off and twist your two ends together, then sew over them. repeat. When you get to the end of the seam pass the needle back through the stitches (about a needles length) and then cut off the thread.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:notjustsomeone
