3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Handsewn Sprits'l
Step 5The Round Stitch
The Round Stitch
The next thing is to sew on the tablings.
I've found it easiest to pin everything in place and then take out a few at a time as I go. But do whatever you feel comfortable with.
The tabling will need to be staggered around the sail to prevent too many layers piling up on top of each other.
Start the luff tabling 1 and 1/2 inches from the bottom and go up to the throat. Butt the head tabling against that and continue around the sail. For the head and foot just make sure that the tabling doesn't end on top of a seam.
For a more traditional look you could even cut the head and foot tablings in 12 inche strips, with a 6 inch peice at each end.
To attach the tabling to the sail on the outer edge I sewed it on with a round stitch. Work from left to right, with the hook on the right. Just take your two peices and insert the needle up through them, repeat. The tension of the thread in this stitch is much less than with the flat stitch. Shoot for 10 to 12 stitches per needle length. Starting, ending, and connecting two peices of thread are the same as in the flat stitch.
When you get to the end of the peice of tabling you're sewing, just continue going around it and switch to a flat stitch.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:notjustsomeone
