Step 6Cutting your barrel channel
erm not that kind of channel . . .a barrel channel to be precise!
Tools and Materials:
- Round bottomed chisels]
- Mallet
- 80 grit sandpaper
- A dowel or other round stick the same size as your barrel
- Rotary tool
First I sanded in a line with the rotary tool so that I could use the groove to line up my barrel but then I was left scratching my head as to how to carve the rest in . . .I eventually bit the bullet and took out the old chisels and mallet and lo and behold . . .someone had damaged the chisels so badly (seriously the edges were shaped like extreme W's) that I wouldn't trust them to cut butter . . .I gave them a new edge on the grinder and went at it. . . You have to be extra careful here and make sure you are completely aware. . . this is not a job you should do when tired since a razor sharp chisel is no joke and one wrong angle will send it skipping off the piece. Bit by bit take out the extra wood and occasionally check the depth and width (as well as roundness) when you get pretty close wrap some 80 grit sandpaper around the stick and push it along the chanel over and over until it's nice and smooth as well as being the right depth . . .this step took me about 2 hours including the sharpening so it's quite a commitment! This will really show errors so make sure you work slowly and carefully.
Add Comment
